EX SWAP NEED SOME POINTERS
Old Jul 22, 2007 | 04:16 PM
jbrokos307's Avatar
Default EX SWAP NEED SOME POINTERS
HELLO PEOPLE OF HONDA TECH I AM THINKING OF DOIN A SWAP IN MY EX CANT DECIDE WHAT SWAP I WANNA DO SO I FIRGURED I ASK AROUND AND GET EVERYONES IDEAS WELL I WANT POWER NOTHIN CRAZY JUST WANT TO HAVE UNDER THERE SO ITS THERE WHEN I WANNA USE IT WANNA DO A N/A MOTOR TO NO TURBOS MABY NITROUS NOT TO SHURE BUT I WANT SOMETHING NOT TO HEAVY AND SOMETHING THATS NOT GONNA HAVE TO BE FORCED IN MY ENGINE BAY NO H22 I LOOKING ALONG THE LINES OF B SERIES MOTORS OR MABY THERE IS SOMETHING ELSE OUT THERE I DONT KNOW IF I AM DOIN SOMETHING WORNG ON HERE PLEASE LET ME KNOW I NEW TO THIS WHOLE ONLINE FORM THING SO PLEASE TAKE IT EASY ON ME P.S. I ALSO GONNA BE DOIN THE SWAP MY SELF AND IF ANY ONE NEEDS TO KNOW ANY THING ABOUT THE CAR WHICH I ALREADY SHURE YOU GUYS KNOW IT ALL BUT IF NOT JUST ASK ILL DO MY BEST TO EXPLAIN THANKS AGAIN JOSH
Old Jul 22, 2007 | 04:36 PM
WebWorks's Avatar
Default Re: EX SWAP NEED SOME POINTERS (jbrokos307)
CAPS!!!
Old Jul 22, 2007 | 04:47 PM
ITS_Dunn's Avatar
Default Re: EX SWAP NEED SOME POINTERS (WebWorks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WebWorks &raquo;</TD></TR><TR><TD CLASS="quote">CAPS!!!</TD></TR></TABLE>
Captain obvious
https://honda-tech.com/zerothread/878010
40+ page thread there based on swaps that are available for your car and what to expect Lots of reading
Old Jul 22, 2007 | 08:21 PM
CapnKrunch's Avatar
Default Re: EX SWAP NEED SOME POINTERS (ITS_Dunn)
LOL.
THERE ARE A LOT OF THREADS HERE ON HONDA-TECH ABOUT THIS!
JUST USE THE SEARCH BUTTON!!
Old Jul 22, 2007 | 08:25 PM
ke98248's Avatar
Well since this gets asked almost daily, me and BauleyCivic have decided that making a thread to showcase, if you will, the swaps.
Some intro swap information
Switching OBD motors
Many people think that swapping in a pre OBDI motor into their 92+ Civic is a good idea. I disagree. First, you'll have to swap the car from OBDI to OBD0 ot try and change the motor to OBDI. If you get a swap older than a 1991, you have to deal with the cable to hydro tranny conversion. The 1992-1993 Integra is the oddball swap of the bunch, being OBD1 and cable tranny. Your stock Civic has a hydraulic transmission.
Swapping from OBDII to OBDI is a common thing more and more now. Although the idea is quite good, it has flaws. If you use a jumper harness, it is very difficult to get the ECM to fit back in it's original location. Also, unless you feel like changing things back at inspection time, it's going to be impossible to pass in some areas. Now places are implementing OBDII testing that will have the tester plug a computer into your OBDII port to check for legality (no pulling the check engine light bulbs anymore to pass).
General swap info and tips
This could be better covered by someone with more swap experience, but I'll put in my $.02. Do it from the top. Just because more people have access to the tools and locations where putting in a swap from the top is easier. Also, make sure you have some way to crack the axle nuts loose. Air tools are a lifesaver when you have to turn bolts in a job like this, as is a torque wrench and a GOOD set of sockets.
If you can follow directions on here and unbolt things and rebolt them with a little wiring, you can do a swap.
A special thanks goes out to JDMlyfestyle for this thread https://honda-tech.com/zerothread?id=983454
JDM Swaps
Honestly, unless these come from a friend in Japan, you're taking a gamble every time. You have no real way to know how many miles are on the engine, nor how it was treated. Just keep that in mind. It has not been proven (no matter how many claims) that these JDM motors make any more HP.
Where to find them
First of all, if you are looking for a USDM motor, I'll suggest local junkyards. They are probally your best bet, as you can look at what you're getting instead of having to order it. Many people on here have bough swaps online, and they have posted their experiences in this thread:
https://honda-tech.com/zerothread?id=50010
Possible Swaps
Now before someone jumps on me and says anything is possible with enough time and money, I know. These are going to be fairly straightforward options with the pros/cons.
D series swaps
These are fairly inexpensive and come in a variety of Civics. IMHO, these are the easiest swaps to drop in. I also don't want to hear a bunch of whining about the opinions on power levels. Of course there are going to be some exceptions to the rule.
Pros
Inexpensive
Decent potential (200 whp or so on stock internals)
OEM parts are cheap
More than enough for most people
The best D series come with ~130 hp tops
Optional factory LSD in the JDM D15B
Cons
Not as much potential as some other motors
Transmission not geared for accelleration
Don't respond to bolt ons well
Only way to get real power out of them is FI
B16
These can be found in the JDM SIR and SIRII (among other JDM cars, which I don't claim to know all of which it came in) as well as the USDM 99-00 SI (EM1) and the 99-00 Canadian SIR.
Pros
160 hp stock
High RPM power
Fairly inexpensive
Good transmission
DOHC VTEC
Cons
113ft/lbs torque (very little more than a D16z6 stock)
Without knowing what you're looking for you can end up with a high mileage JDM model
Under 4k or so it feels just like a D16
B18B
This is the motor in the non Type-R and non GSR Integra.
Pros
Good torque for a 1.8L (127 ft/lbs)
Inexpensive (even cheaper than a B16)
142 hp (more than any stock D series)
Boost heads love them
Cons
No VTEC
Longest B series transmission
B18C1 (or JDM B18C)
These come out of an Integra GSR.
Pros
Good Hp and TQ numbers (170, 121 ft/lbs respectively)
DOHC VTEC
Tons of potential
High revving
Cons
Expensive
Becoming moreso as people keep scooping them up
Slighty longer tranny than the ITR and B16
B18C5 (or JDM B18C)
This is found in the Integra Type-R. IMHO this is the best swap for a Civic.
Pros
GREAT HP and TQ numbers (195 and 134 ft/lbs)
High revving
Hand built motor from Honda
Best transmission for a B series from the factory
Red valve cover
Cons
EXPENSIVE
If JDM ITR is used, the 36mm axle 32mm hub problems occur
B16B
This is the motor found in the Civic Type R found all over the world.
Pros
185 hp 117 ft/lbs
High revving
Good top end power
Red valve cover
Cons
Expensive- almost as much as an ITR for lower performance
Very little torque still, have to rev the motor to make power
B20
Pros
Great torque (133 ft/lbs)
good boost motors
inexpensive
B20z=146hp
Cons
Thin cylinder walls
Have to peice together a swap for a Civic (can't drop it in with a B20 tranny)
Won't pass BAR (light truck motor in a car)
Low hp in the B20b(126 hp)
H22/JDM F20B
Pros
200 hp
H22=156 ft/lbs torque
F20B=145 ft/lbs torque
Great torque
DONT WEIGH THAT MUCH MORE THAN A B SWAP!!
https://honda-tech.com/zerothread?id=684550
Cons
Harder to install than a B/D motor
transmission feel is vague IMHO
Less info out there for the swap (aka, less experience as they are less common)
Price of swap is comperable to a B18C5 after everything is said and done (mounts, etc)
K20
This can be found in the new EP3, the RSX (base and Type S) as well as other cars across the world (RSX R, etc). This is the future of the swap IMHO. There is a writeup on installing one of these in one issue of Sport Compact Car magazine (June 2004 I *think*)
Pros
200 hp 158 ft/lbs torque (RSX R)
I-VTEC
Respond VERY well to bolt ons
6 speed transmission
Most have very low miles
Cons
Still super expensive
More difficult swap than a B or D
Well, there you have it people. I've outlined some of the pros cons on some of the most popular swaps.
H2B/F2B
Pros:
All pros of H22/F20B
No custom mounts
Tons of potential
Cons: requires H2B adapter kit
Requires MINOR usage of angle grinder
Requires spacers under the hood
For more H2B information
https://honda-tech.com/zerothread?id=1998426
Check out the FAQ thread for more info on how to install them.
https://honda-tech.com/zerothread?id=642479
Most of these HP/TQ numbers were taken from Hmotors online if I didn't know them. Don't bite my head off if they aern't correct. I don't claim to be a walking encyclopedia, so I have had some help.
Old Jul 22, 2007 | 08:26 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: EX SWAP NEED SOME POINTERS (ke98248)
Hooray someone included H/f stuff other than me!!
Old Jul 22, 2007 | 08:28 PM
exh22's Avatar
a h22 did not take a lot of mods to stick into mine. all i had to do was to buy motor mounts and to cut a small hole for the shifter. other than that i just lost my ac. If you live where i do that sucked but the power is good. it was fun beating mustang and other V8s. The only thing about a h22 it takes alot to keep it running smothly. You have to watch your RPMs they will get you into trouble quick. i would go with a B16 it is goood for a daily driver.
Syndacate's Avatar
Default Re: EX SWAP NEED SOME POINTERS (ek forever guy)
LS
LS Integra motor + 100 shot of nitrous for track day.
You won't regret it !!!
Don't listen to any dick tell you "the gearing is MADDDDD long on the LS" - it's not.
Old Jul 22, 2007 | 08:31 PM
Ek Forever y0!
Default Re: EX SWAP NEED SOME POINTERS (Syndacate)
I think it's more the H-series transmissions that have problems at upper RPM's than the engines themselves. I've conversed with several HPD'ers that complain about the slushyness of the H tranny at upper rpms.
Old Jul 22, 2007 | 08:33 PM
exh22's Avatar
that is ture. the cable shift feels like crap. i liked it when i had a rod shifter.
Old Jul 22, 2007 | 09:00 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">I think it's more the H-series transmissions that have problems at upper RPM's than the engines themselves. I've conversed with several HPD'ers that complain about the slushyness of the H tranny at upper rpms.</TD></TR></TABLE>
This is the first I've heard of this - I drove my friend's H22 (H trans) hatch for a week or something to try to see if all the bitching on H-T about it "making your handling sucks due to the exra weight is true" (it's not) - and I didn't feel any problems - and I put that thing through its paces...
Again, I've never looked into this slushyness problem, but .
Old Jul 23, 2007 | 05:15 AM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
Again, I've never looked into this slushyness problem, but .</TD></TR></TABLE>
You have to be a ricer and hit the rev limit.
Old Jul 23, 2007 | 05:40 AM
Syndacate's Avatar
You have to be a ricer and hit the rev limit. </TD></TR></TABLE>
Naw, that's the thing, I was. I pounded the **** outta it and tested it against every car or truck i found. I was a complete ******* with it, and it acted just as most 2.2 or 2.4L motors act - just with a higher redline. Though I pushed it all the way to the redline (chipped P03) quite a few times and it acted pretty normal....blah..something he coulda did to make it "not sluggish?" - He didn't do any changes besides dyno tuning it with I/H/E on a stock H22 basemap.
EDIT:
What is it, an air flow problem or something?
Old Jul 23, 2007 | 06:33 AM
Ek Forever y0!
Everything I've heard is just with the transmission itself not enjoying being winded out.
Old Jul 23, 2007 | 08:52 AM
jbrokos307's Avatar
thanks guys anyone here in md selling any stuff
Old Jul 23, 2007 | 09:00 AM
Syndacate's Avatar
Default Re: (jbrokos307)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbrokos307 &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys anyone here in md selling any stuff</TD></TR></TABLE>
Wait until you're not a trial anymore then go to the market place.
Also, if you're looking for specific stuff, post it in your signature.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Everything I've heard is just with the transmission itself not enjoying being winded out.</TD></TR></TABLE>
I see, hrm, he had a regular H22 trans on it, dunno, but good to know I suppose. Unfortunately he moved so I can't test drive it again. Oh well.
Clarksonrocks
Honda Civic (2001 - 2005)
May 23, 2006 12:17 PM
DRKSol
Feb 26, 2004 04:24 PM
kingpen
Sep 22, 2002 12:53 PM
kingpen
Sep 1, 2002 12:16 PM
DaddyFatSacks
Aug 9, 2002 11:23 PM
