MAP Sensor Issue
Old Jul 16, 2007 | 04:41 PM
5_Lug_B's Avatar
* B A N N E D *
Default MAP Sensor Issue
Ok, so me and a friend just finished swapping a B16 into his 95 EX coupe and everything is running fine with the exception of the MAP Sensor. I even took my MAP sensor off my B16 and put it on his to see if it was bad or not and the CEL still came on even after I reset the ECU. Now the weird thing is after I reset the ECU the engine idles low and then about 45 seconds into idling it shoots up to anywhere between 2000 - 2500 rpms then it throws the CEL code. Could it be that when a vaccum leak occurs it sets off the CEL?
Old Jul 16, 2007 | 08:28 PM
slowcivic2k's Avatar
Default Re: MAP Sensor Issue (5_Lug_B)
I would check your MAP sensor wiring and make sure it is connected properly.
Is the CEL MAP related?
Old Jul 16, 2007 | 10:20 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: MAP Sensor Issue (slowcivic2k)
yes
Old Jul 17, 2007 | 05:14 AM
cpl rampage's Avatar
Did you get the TPS and MAP conectors reversed? they are the same size connectors
Old Jul 17, 2007 | 12:08 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: MAP Sensor Issue (cpl rampage)
No they were on right. Turns out the ECU was actually bad. Has this ever happened to anyone else before?
Old Jul 17, 2007 | 04:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5_Lug_B &raquo;</TD></TR><TR><TD CLASS="quote">No they were on right. Turns out the ECU was actually bad. Has this ever happened to anyone else before?</TD></TR></TABLE>
And how did you come up with that determination..... ECU's just don't go bad, back in the days of old they did, but that is few and far between for most modern electronics...
hondalove414
Mar 20, 2011 08:11 AM
§95HATCH§
Apr 6, 2009 12:40 PM
msinsky14
Nov 25, 2008 05:57 PM
5_Lug_B
Jul 18, 2007 12:24 PM
lysergican
Jul 12, 2002 04:29 AM
