MAP Sensor Issue
* B A N N E D *
MAP Sensor Issue
Ok, so me and a friend just finished swapping a B16 into his 95 EX coupe and everything is running fine with the exception of the MAP Sensor. I even took my MAP sensor off my B16 and put it on his to see if it was bad or not and the CEL still came on even after I reset the ECU. Now the weird thing is after I reset the ECU the engine idles low and then about 45 seconds into idling it shoots up to anywhere between 2000 - 2500 rpms then it throws the CEL code. Could it be that when a vaccum leak occurs it sets off the CEL?
Re: MAP Sensor Issue (5_Lug_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5_Lug_B »</TD></TR><TR><TD CLASS="quote">Ok, so me and a friend just finished swapping a B16 into his 95 EX coupe and everything is running fine with the exception of the MAP Sensor. I even took my MAP sensor off my B16 and put it on his to see if it was bad or not and the CEL still came on even after I reset the ECU. Now the weird thing is after I reset the ECU the engine idles low and then about 45 seconds into idling it shoots up to anywhere between 2000 - 2500 rpms then it throws the CEL code. Could it be that when a vaccum leak occurs it sets off the CEL?</TD></TR></TABLE>
have you jumped the ecu for the code?
https://honda-tech.com/zerothread/1901557
you should read a code 3 or 5. one of those is a code for the actual map being bad, the other is for a vacuum leak. i don't remember which one since it's been awhile, but most likely it's a vacuum leak.
* B A N N E D *
Re: MAP Sensor Issue (philosofy1)
Yea, when the vaccum leak first occurs it then throws a code five. So do you think it is throwing a code due to the vaccum leak?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5_Lug_B »</TD></TR><TR><TD CLASS="quote">Yea, when the vaccum leak first occurs it then throws a code five. So do you think it is throwing a code due to the vaccum leak?</TD></TR></TABLE>
well, if you swapped out the map sensor with the one off your car and yours is still good, then i would say it's throwing the code due to a vaccum leak.
