Quick question
thank you guys i appreciate it. i've been leakin oil all over cuz, ive been usin a rubber hose for an oil line
but if i wanted to make my own custom fittin oil line, where can i get the oil line from without buyin it online?
if you dont want to order online. your local autozone or o'reilys should be able to get earl's or russell fittings for you. as mentioned above you will need a 1/2npt to -10AN (male), 2 -10AN hose ends, -10 stainless line, and a -10AN weld-on bung for the oil pan.
also depending on your set-up you may one to use a combination of 45* fittings with the straight hose ends. what is your setup so we can be more helpful?
i have a td04h greddy turbo with greddy manifold and downpipe. right now im just usin a rubber vac hose with a metal clamp. and its not doin a good job haha, cuz it cut through the rubber and now im leakin oil everywhere
well in that case you may need some different fittings. im not sure if the td04h has a 1/2" oil return, other that that you should be good to go. also you will probably need a matching return flange.
C1V1CS1
Oct 16, 2002 12:23 PM
