water temp gauge
i have a autometer electric water temp gauge, and was wondering where should i instal the coolant temp sending unit? also i wanted to get a half sized radiator but dont wanna spend too much money on it. some one said that i can get a dodge neon radiator and it will fit fine but i dont know what year. thanks. by the way its a 89 crx dx with a manual trans
this is the lazy man's way out......but.......
i just picked up a used gauge and it has a greddy adapter. basically it's a small pipe with a threaded bung for the temp sensor. it fits inline with a coolant hose.
http://cgi.ebay.com/ebaymotors...ZWD1V
the sensor just screws right into the top, and you clamp that somewhere inline with a radiator hose (i'm going to put it in the lower rad hose to keep it out of sight mostly).
Tap the metal water tube in the of you block that will be the cheapest way "not easiest" and the most precise, due to it being so close to the blocks return
for the tapped Greddy Tee, but you have to remember that the further from the block after coolant has passed through you are the more inaccurate the reading will be; that is of course if you want to know what temp the engine's coolant is at and not the temp @ the radiator.
IF you use that adapter don't put it in the lower hose, it doesnt matter what temp the water comes out of the rad, you want to know the engine temp, so it has to be in the upper hose. You can also make one of those for like $10 just get the proper size steel pipe to fit a rad hose(exhaust coupler works good) and then just drill a hole in it and weld a bung on that matches the threads of the sending unit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">IF you use that adapter don't put it in the lower hose</TD></TR></TABLE>
i'm glad you said that.
thank you
thank you
This is how I did mine. Keep in mind I have the heater controll wide open so the coolant constantly is flowing. I chose the heater hose leading to the firewall as a source for my water temp gauge. Works like a charm.
Gauge mounted.
Gauge mounted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil »</TD></TR><TR><TD CLASS="quote">That looks like absolute crap.</TD></TR></TABLE>
wtf n00b he's just showing another way to do it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil »</TD></TR><TR><TD CLASS="quote">I get excessively drunk at inappropriate times, disregard social norms, indulge every whim, ignore the consequences of my actions, mock idiots and posers, sleep with more women than is safe or reasonable, and just generally act like a raging ********.</TD></TR></TABLE>
o i c
o i c
Lets see your setup?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Death »</TD></TR><TR><TD CLASS="quote">
Lets see your setup?</TD></TR></TABLE>
I don't have one. I don't need one. If I did though, I wouldn't shop at a home supply store for my parts.
I don't have one. I don't need one. If I did though, I wouldn't shop at a home supply store for my parts.</TD></TR></TABLE>
honda tech is a cool place, don't be a jerk, keep your OPINIONS to yourself. Give some suggestive critical comments if you have too, but don't just outright be a jerk to anybody else. Thanks.
i use the buddy club adapter (which looks very similar to the greddy). i have mine in the top radiator hose.
http://cgi.ebay.com/ebaymotors...wItem
Why pay $25 for an adapter when you can make one for $3? It all works the same...
Plus who tries to impress people with their water temp gauge sending units?
Why pay $25 for an adapter when you can make one for $3? It all works the same...Plus who tries to impress people with their water temp gauge sending units?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90sedan »</TD></TR><TR><TD CLASS="quote">Plus who tries to impress people with their water temp gauge sending units? </TD></TR></TABLE>
I don't care what other's think. I care what I think. If I had that in my car, I'd laugh at myself. Do it right or don't do it at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil »</TD></TR><TR><TD CLASS="quote">That looks like absolute crap.</TD></TR></TABLE> may I ask how you would set this up then?
Do it right or don't do it at all.</TD></TR></TABLE>
What is wrong with the way I did things? The gauge works like a charm and the sending unit isn't visible unless you look for it. Tell me, can you see it??
Didn't think so.
Didn't think so.
Sorry Home depot isn't JDM enough for you
There is nothing wrong with his setup, get over yourself.
I installed mine similar to Mr Death with "suppy store" fittings. I used one of the coolant lines that went from the back of the thermostat housing to the head. Works perfect and was under $10.
There is nothing wrong with his setup, get over yourself.I installed mine similar to Mr Death with "suppy store" fittings. I used one of the coolant lines that went from the back of the thermostat housing to the head. Works perfect and was under $10.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 »</TD></TR><TR><TD CLASS="quote">Sorry Home depot isn't JDM enough for you
There is nothing wrong with his setup, get over yourself.</TD></TR></TABLE>
JDM? Did I say anything about that? There's better ways to do it. Much better. Cleaner installs that dont look so crappy.
There is nothing wrong with his setup, get over yourself.</TD></TR></TABLE>JDM? Did I say anything about that? There's better ways to do it. Much better. Cleaner installs that dont look so crappy.
JDM? Did I say anything about that? There's better ways to do it. Much better. Cleaner installs that dont look so crappy.</TD></TR></TABLE> please post up some pictures or link them...I bet you will be spending much much more for something that does the exact same process. Also, just wondering are you saying the guages in the cabin set up is "crappy" or just the tee for his sender?
The gauges in the car look all right. It's that crappy T. That's just my opinion. Why not just tap into a flange instead of introducing a bunch of leak possibilities? It may take a little longer, but it will look better and most likely function better.
hey what happened to honda tech any ways? keep ur opinions to yourself, buddy. i did it the same way mr. death did it and it works great. in fact, i probably got the idea from him in the first place over a year ago. you cant even see it like he said unless your looking. i have a boosted b16 under the hood with a wire tuck and the ugly water temp sensor adapter doesnt bother me a bit cuz I CANT SEE IT.
project civic
Mar 16, 2006 09:46 AM
