Tial Wastegate stuck open
Old Jun 11, 2007 | 02:44 AM
90sedan's Avatar
Default Tial Wastegate stuck open
Alright, so i just recently got my car running after going boost. Well i noticed that at idle exhaust is coming out of my dumptube. I took the dumptube off and sure enough the WG is stuck open.
I bought it used from a member on here. The valve seat is in, i just checked. It is only open about half a cm. I can't get the valve to move up or down when i press on it.
I am going to take apart the WG tomorrow. Anything i should look for? What normally causes this? Faulty WG?
Thanks.
Old Jun 11, 2007 | 03:07 AM
DaveF's Avatar
Default Re: Tial Wastegate stuck open (90sedan)
do you have your vacum source hooked into the top or the bottom of the WG ? if its in the top. the valve might open @ idle with a very low psi rated spring in the gate.
Old Jun 11, 2007 | 05:23 AM
TiAL's Avatar
sounds like someone used leaded fuel with a pump valve
look for corrosion on the valve stem, or the sweet sweet smell of race gas
Modified by TiAL at 7:06 AM 6/11/2007
Old Jun 11, 2007 | 10:02 AM
90sedan's Avatar
Vacuum source is hooked up to the side, i'm not running a boost controller. A 7.5 psi spring is in it.
Honestly, the lower valve stem looks fine, it was just black from carbon.
Max500
Aug 6, 2011 05:40 PM
ludatic98
Dec 8, 2009 08:34 AM
4dek
May 27, 2008 10:55 PM
Turbo_Mike
Jul 14, 2005 12:07 PM
Chuck Dean
Aug 9, 2003 04:20 PM
