Need help with this turbo have a couple Qs
Old Jun 7, 2007 | 09:20 PM
mortificationrock's Avatar
Default Need help with this turbo have a couple Qs
I need to know how to adjust the psi in this turbo also wher does the oil feed line go and where does the return go!!! Sorry for the noob *** Q!! But i appreciate any body wiiling to help And second how the *** do you insert images???? Anyways i have a gredd t04 !!! Will post pic after i learn how to
Old Jun 7, 2007 | 09:54 PM
.RTErnie's Avatar
Default Re: Need help with this turbo have a couple Qs (mortificationrock)
um...dont post in kills.
Boost Pressure rated in Pounds per Square Inch is adjusted via a wastegate (external or internal).
The oil feed and drain are located on the center section of the turbocharger. Depending on if your turbo is water cooled or not... Watercooled turbos will have 4 holes in the centersection. non-h20 cooled turbos will have two.
The oil holes are on opposites sides of the charger...IE 180 degrees apart. The oil ports will be easy to identity because the feed should be small approx 1/8"NPT and the drain should be a rectangular 1/2"x1/2" port with two bolt holes on either side of the port.
The coolant lines should be a larger 1/2" NPT (or some thread) and located 180 degrees from each other.
go to http://www.turbobygarrett.com and go read google on turbochargers and how they work.
I WOULDN'T RECOMMEND YOU ATTEMPTING TO TURBOCHARGE YOUR CAR AT THIS POINT.
hell i even made a paint diagram for you :-P
Modified by .R T E r n i e at 7:10 AM 6/8/2007
VTEC_PRODUCTION
Oct 17, 2010 12:39 PM
Mikes2000civicsi
Aug 5, 2010 07:35 PM
ninja8oi
Jun 12, 2005 06:20 PM
2000vsm
Aug 29, 2003 08:08 AM
Scott - 93HB Si
Sep 4, 2002 04:14 AM
