help with axleback removal
Old Jun 6, 2007 | 04:05 PM
oem_CD5's Avatar
Default help with axleback removal
i've sprayed wd-40 on a couple of times and i've tried to wrench off the bolts with my strength. it hasn't budged. do you have any suggestions?
here are some pictures:
Old Jun 6, 2007 | 04:09 PM
02 accord's Avatar
Default Re: help with axleback removal (oem_CD5)
Impact wrench. Or stick a regular wrench on there and start whacking it with a BFH. Helps if you have lifetime warranty on the wrench.
Old Jun 6, 2007 | 06:18 PM
oem_CD5's Avatar
Default Re: help with axleback removal (02 accord)
what's the difference between an impact and torque wrench? BFH? big expletive hammer? am i supposed to hold one side and wrench the other? is there a correct side to wrench on or does it not matter?
Old Jun 6, 2007 | 06:41 PM
02 accord's Avatar
Impact wrench works the same way as if you use a regular wrench and hit it with a hammer. Torque wrench, on the other hand, tightens bolts to a specific torque. Yes, you got the BFH right.
I would start by wrenching on the nut. That way, only the nut will turn instead of the whole bolt which is sitting in the flanges (more friction). Start by not holding the bolt. If it starts turning, then you will have to put another wrench on it to keep it from turning.
Old Jun 7, 2007 | 10:30 AM
hitekper4mance's Avatar
doubt an impact will fit up there. If it does it will do the job. Good luck with the BFH. If its not workin the way you want, there are other ways.
Old Jun 7, 2007 | 01:13 PM
inspyral's Avatar
Get a longer breaker bar.
Old Jun 7, 2007 | 01:58 PM
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">Get a longer breaker bar.</TD></TR></TABLE>
I was thinking that and even an extension on that if you need. Leverage is a huge factor. But, then I was thinking...will there be enough room down there to work it. He can even just take the exhaust off of the hangers to drop it low enough for an impact.
Post up when ya got it done and what worked for ya.
Old Jun 7, 2007 | 02:30 PM
Crazydave's Avatar
Default Re: (hitekper4mance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hitekper4mance &raquo;</TD></TR><TR><TD CLASS="quote">
Post up when ya got it done and what worked for ya. </TD></TR></TABLE>
It doesn't need leverage... it needs the hit of a impact.
besides, a long breaker bar is just going to twist it all to hell.
so you can put the closed end of a wrench on it, and swing away and probably hurt your knuckles
-or-
In the past I have done the following to get the bolts off.
1.) soak with WD-40 and/or Rust-b-gone or some sort of stuff like that and then soak again... let it sit for 20 minutes each time.
2.) Impact gun
It needs a wrench on side and the impact on the other.
IT WILL FIT I have done it.
an impact swivel socket does make it easier though.
Old Jun 7, 2007 | 02:32 PM
Crazydave's Avatar
Default Re: (Crazydave)
here is an impact gun:
it is also very usefull in removing:
axle nuts,
crank pulley bolt,
other stuck bolts.
Old Jun 7, 2007 | 06:42 PM
oem_CD5's Avatar
yea, i don't have an impact gun nor do i want to go out and buy one. i think i'm just going to order all the parts that i need and bring it either to honda or a muffler shop. it shouldn't cost much for them to get the bolts off and bolt on a new muffler. can you guys double check to see if i have everything that i need?
the muffler: (i don't see the difference between the first and fourth)
http://shop.hondaautobodyparts...O&x=1
the gasket: (i believe it's the second one)
the bolts:
http://shop.hondaautobodyparts...de=HO
i have a 94 accord dx
Old Jun 7, 2007 | 09:18 PM
sitinthehall's Avatar
Default Re: (oem_CD5)
put on a breaker bar and kick it.
Old Jun 8, 2007 | 02:59 AM
GSRpoweredSI's Avatar
get some industrial grade screwloose and hose it down i mean half a can so it will penetrate and soak. with that let it soak for a couple of minutes and hit it with a break bar. hope that helps.
Old Jun 8, 2007 | 05:17 AM
Mikey3000's Avatar
Default Re: (GSRpoweredSI)
PB Blaster works better than WD-40. Get yourself a can of that and spray it on the nut and threads. It'll penetrate like none other. Then put a socket wrench on the nut and put your jack handle (top half) on the socket wrench. Also make sure you put the right size socket on the nut. Don't let the rust fool you into thinking the nut is bigger than it actually is, you'll end up stripping the ever-living **** out of the nut then you'll really hate your life.
Old Jun 8, 2007 | 01:31 PM
stumpyf4's Avatar
Default Re: (Mikey3000)
Just cut the u-bolt... only other way is to heat the bolt till it's red hot then try. Keep the heat away from the gas tank.
Old Jun 8, 2007 | 01:41 PM
EG civic's Avatar
Default Re: (stumpyf4)
If ur replacing the whole exhaust system just cut the piping with a saw. I did that and saved me a lot of problems.
Old Jun 8, 2007 | 02:23 PM
Default Re: (EG civic)
i think he is just doing the "axle back" not the cat back. Oh and I dont think the U-Bolt is the problem. I am assuming he wante to seperate it from the connector. Looks like the muffler already broke off.
Old Jun 8, 2007 | 09:20 PM
oem_CD5's Avatar
yea the stock mufflfer broke off. it's supposed to be one whole piece from the axle back but something must have happened. the muffler and the rest of the axle-back piping was connected together not by welding but by that thing that you see in the first picture. now that the muffler is off, i need to take off the rest of the piping in order to install a new axleback. i have work all weekend so i'll get back to you all on monday when i try pb blaster. thanks for the help
Old Jun 13, 2007 | 12:59 PM
oem_CD5's Avatar
what's the difference between a breaker bar and a torque wrench? the breaker bar looks like a ratchet with a long handle and the torque wrench looks like the best of both worlds. it has the long handle and then you'll be able torque bolts on to a certain spec.
Old Jun 13, 2007 | 03:07 PM
pretty much but dont want to use a torque wrench because those are calibrated devices. (as far as I know).
Old Jun 14, 2007 | 12:44 PM
95strfytr's Avatar
Impact for sure. If that fails, cheater bar.
invisible
Apr 10, 2007 03:19 PM
NuRon
Mar 31, 2007 09:41 PM
G2DAB18
Dec 29, 2005 12:06 PM
Tad
Oct 24, 2004 07:09 PM
jonsteR
Aug 10, 2001 08:55 AM
