RTV silicon instead of gaskets?
Old Jun 2, 2007 | 06:04 PM
wrinkles's Avatar
Default RTV silicon instead of gaskets?
is it a bad idea to instead of using gaskets in between the manifold, adapter plate, and turbo to just use rtv silicon? or is this acceptable? its the high temp gasket maker rtv silicon for the reference
Old Jun 2, 2007 | 06:09 PM
Jared's Avatar
use gaskets.
SwappedTURBOegg's Avatar
lol
Old Jun 2, 2007 | 08:04 PM
HiProfile's Avatar
Default Re: (SwappedTURBOegg)
I could see rtv for the intake mani on an NA car, but deffinately not on a boosted car, and certainly not for the exhaust. You'll be cooking that silicone <U>well over 1000F</U>, and not much silicone is rated for over 800F. FYI Permatex's max-temp copper silicone rtv silicone is rated for <U>700F</U> max.
Old Jun 2, 2007 | 10:21 PM
BlueSi2k's Avatar
Default Re: (HiProfile)
you dont really need gaskets as long as everything is true. I never used any gaskets between turbo/mani/dp or wastegate and never had any leaks.
Old Jun 4, 2007 | 01:46 AM
a1320honda's Avatar
Default Re: (BlueSi2k)
Just so your not alone in your thoughts, this was at out spring honda-tech meet.
Old Jun 4, 2007 | 01:52 AM
SD_Lurker's Avatar
HT White Ops
Default Re: (a1320honda)
^^wow all that work to go turbo and they didn't even feel the need to get gaskets. HMT at its best right there. That thing is hideous.
pcguy760
Aug 29, 2008 07:03 PM
blakacintegra
Jun 20, 2007 05:21 PM
JDM00SI
Nov 2, 2005 09:14 AM
JusT a Cx
May 12, 2004 08:58 AM
KStuned
Apr 3, 2002 04:08 PM
