Gasket for turbo?
Old Nov 2, 2005 | 04:25 AM
JDM00SI's Avatar
Default Gasket for turbo?
so we all know what gaskets are, i think they are a brilliant idea. So i going to be using a inline pro and a gt35e, well to sum it up i thought there was a gasket to go between it. After talking to a shop, he states that the turbo forms its own gasket from all that heat/pressure. well before he told me this, based on Honda Tech i was planning on using a gasket. Do yo guys use gaskets? Do you guys face problems?
thanks
Old Nov 2, 2005 | 04:26 AM
JDM00SI's Avatar
do you guys use a gasket between your wastegate and manifold? i will be using a Tail 38mm.........
Old Nov 2, 2005 | 05:11 AM
ramrod's Avatar
Default Re: (JDM00SI)
I would coat both the turbo flange on mani and the flange on the turbo with copper spray and be done with it.
As for the wastegate, from what I've read, the firing ring makes the seal between the wastegate and manifold.
But I used the gasket that came with my wastegate.
Good luck
Old Nov 2, 2005 | 05:15 AM
7k rdlne's Avatar
Default Re: (large farva)
i dont use a gasket between my wastegate and manifold or my turbo and manifold, no problems here, when i first put the turbo on i used a gaste between the wastegate and it blew out after about 1hr
Old Nov 2, 2005 | 05:47 AM
JDM00SI's Avatar
hmmm... re bump
Old Nov 2, 2005 | 08:44 AM
brizjuan's Avatar
I use no gasket from turbo to manifold... just go metal to metal and let the carbon build up... best gasket..
Old Nov 2, 2005 | 09:14 AM
JDM00SI's Avatar
Default Re: (brizjuan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brizjuan &raquo;</TD></TR><TR><TD CLASS="quote">I use no gasket from turbo to manifold... just go metal to metal and let the carbon build up... best gasket..</TD></TR></TABLE>
good idea
bvilleteggy62
Oct 15, 2007 12:35 PM
hoya_10fintec
Dec 24, 2005 10:37 PM
grndcont
Jun 3, 2005 06:50 PM
Ls1 FD3s
Jan 22, 2005 05:18 AM
KStuned
Apr 3, 2002 04:08 PM
