At what PSI does the oil light turn on?
I know it sounds like a dumb question, but its related to my gauges. I have a oil distribution block for my guage+turbo, and since I swapped the ports the two use, I'm getting 25-50% less oil pressure than before. At idle before adding the turbo kit, it was always >15psi on the gauge, now it drops to almost 5psi.
The problem with that is: I knew it was perfect pressure before adding the kit, but between adding it and changing spots, I really can't recall seeing where it was. I'm sure I saw good pressure at that point, but I just can't visually remember it. A engine builder I know said he's seen that a few times with oil dist. mani's, but I just want to be sure.
why do you have the pressure gauge and the turbo on the same circuit? Since oil is being fed into the turbo there is going to be a pressure drop at the gauge.
