Need some help car wont start after i replaced bottom end
Old May 10, 2007 | 09:22 AM
marcusgnf's Avatar
Default Need some help car wont start after i replaced bottom end
so blew my motor up when it was turbo so, i had to go get a bottom end for it due to a spun rod bearing(motor is a y8) everything went smooth, new belts ,clutch, alternator, etc but now im go to start
1 ran real rough so i shut it off and check timing marks there ok
2 went over the motor made sure everything was plugged up corectly still runs rough
3 had to change spark plug wires around becuase i thought they werent in the right firing order
after that now it wont start at all it cranks but doesnt start
i used this firing order diagram http://www.we-todd-did-racing....k1NDE
Shot of the motor
any help would be greatly aprreciated
EDIT: ran some test and found out the car isnt getting spark, now im just trying to figure out what could have changed in the last 1/2 hour to make it do this
EDIT:
i dont wanna do this nor do i have the cash for it but if i cant get this thing fixed soon ima have to tow it to a shop because i need this car running pretty soon, stil no suggestions
1 has spark ( weak)
2 cranks but doesnt start ( started before but ran like crap could of been because of firing order)
3 Not a fuel problem because i have pressure at the fuel rail and can hear fuel pump prime
4 when i try to start the car I hear a clicking sound in the passenger side area, could be coming from ECU, main relay, or fuse box under hood
Modified by marcusgnf at 7:01 PM 5/10/2007
Modified by marcusgnf at 3:22 AM 5/13/2007
Old May 10, 2007 | 10:32 AM
marcusgnf's Avatar
update: car starts again but runs rough and dies, only getting spark to cylinders #3,#4
Old May 10, 2007 | 10:43 AM
Civichx1998's Avatar
Looking at the valve cover
4-3-2-1
looking at dist....
3 4
1 2
Thats the way ive always know it... I think the picture you have from that site is wrong..
Old May 10, 2007 | 09:12 PM
marcusgnf's Avatar
Default Re: (Civichx1998)
ok ill try it out tomorrow otherwise im going to try getting another distributor, i cant find any other reason why it would only spark on two cylinders
Old May 10, 2007 | 09:56 PM
littleredcivic's Avatar
check wires with a meter, check cap condition, switch wires around to troubleshoot by process of elimination.
Old May 10, 2007 | 10:05 PM
Luserkid's Avatar
Default Re: (littleredcivic)
Old May 11, 2007 | 06:28 AM
marcusgnf's Avatar
^^^yeah thats how their routed
Old May 11, 2007 | 06:29 AM
marcusgnf's Avatar
checked cap and rotor and they look pretty new
Old May 11, 2007 | 08:11 AM
marcusgnf's Avatar
Default Re: (marcusgnf)
got spark now but still no start, car makes this weird clicking sound by the ECU or Fuse box
Old May 11, 2007 | 08:27 AM
zerovandez's Avatar
Dude, I think you got the wires in the wrong spots. From dizzy it should be
34
12
That picture has it:
13
24
If you have your wires like that picture, then change it.
Old May 11, 2007 | 08:34 AM
Luserkid's Avatar
Default Re: (zerovandez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">Dude, I think you got the wires in the wrong spots. From dizzy it should be
34
12
13
24
If you have your wires like that picture, then change it. </TD></TR></TABLE>
You do know that 3 and 4 need to be where the flat part of the dist. is right? Not all dist are going to be straight up. If he did it your way itll be off.
Clicking noise is main relay. If that goes then you wont be able to start your car.
Old May 12, 2007 | 10:47 AM
marcusgnf's Avatar
Default Re: (Luserkid)
took a main relay off of another honda of mine still no start just clicking and cranking,
Old May 12, 2007 | 01:57 PM
zerovandez's Avatar
Learn something new everyday!
Old May 12, 2007 | 06:22 PM
marcusgnf's Avatar
1 has spark ( weak)
Old May 12, 2007 | 06:41 PM
rs-r's Avatar
A.)
Bring these two to your nearest part's store to have them test check to see if they are still good or bad
-alter
-starter
B.)
If I'm right it might be your <U>battery</U>.
if those (alternator and starter) are good and with that...clicking noise from your fuse or reley/s under the driver dash.
Your battery is low and doesn't have enough voltage to pump up some juice.
C.) If this isn't any help then
Old May 13, 2007 | 12:51 AM
FlatBrokeHatch's Avatar
Default Re: (rs-r)
Check all your grounds.
Old May 13, 2007 | 07:20 AM
marcusgnf's Avatar
Default Re: (FlatBrokeHatch)
well its a brand new alternator (i month old) so im pretty sure its not that, and i tried to starting it with jumper cables, and it started once but ran like crap, and then the next day did the same thing with jumer cables and it wouldnt start
as for grounds i checked them before but a second time wouldnt hurt so thats what im about to do now
Old May 13, 2007 | 08:46 AM
trrbl1bmx's Avatar
As previously mentioned your spark plug wires are in the wrong place. Here is a picture of how it should be. Whoever showed you that other firing order should be shot.
Old May 13, 2007 | 09:11 AM
hatch96y7's Avatar
Default Re: (p00n)
look at how the dizzy is mounted on his car *** hole then delete ur statement.
the dizzy is croocked to the right.
so u need to get shot
Old May 13, 2007 | 10:08 AM
marcusgnf's Avatar
Default Re: (hatch96y7)
well im pretty sure i have the firing order correct now (went on autotrader and found some detailed engine photos of people with y8 engines) but yeah your both right
Old May 13, 2007 | 10:11 AM
marcusgnf's Avatar
checked grounds again and there good,
Old May 13, 2007 | 06:39 PM
marcusgnf's Avatar
bump
Old May 13, 2007 | 06:51 PM
1992cxcivicEG's Avatar
Default Re: Need some help car wont start after i replaced bottom end (marcusgnf)
five things a gasoline engine needs to run
1. fuel
2.compression
3. spark
4. timeing
5. proper air flow
you must have a prolbem with one componet, or one or more is not working together.... think of it as team work
Old May 14, 2007 | 05:45 AM
marcusgnf's Avatar
Default Re: Need some help car wont start after i replaced bottom end (1992cxcivicEG)
yeah i wish it was that simple but i can pretty much say i have all those
except im not sure on spark because sometimes its there other times its not
and i havnt checked compression
Old May 15, 2007 | 08:53 AM
Crispy's Avatar
Um dude, if thats a picture of your car your firing order is --&gt;WRONG&lt;-- Which is what most everyone here is trying to tell you.
98civichb
10
May 22, 2008 05:26 PM
danny_ha
21
Nov 14, 2007 08:21 AM
x3kevin
May 15, 2007 12:51 PM
sik96teg
Mar 11, 2006 10:50 AM
geezer06
Nov 17, 2003 07:31 PM
