car won't start, need help
Old 11-17-2003, 10:43 AM
geezer06's Avatar
Default car won't start, need help
i need help! my car won't start. it's a 5g coupe with 96 gsr. here's what's happening. i recently built the head..p/p, dual springs, retainers, etc...well, after putting everthing together, i fired it up. it started. i turn it off and went to sleep for the night. next day, tried starting it,now the car won't start! it'll try to start but it seems like it doesent have enough power to start... i check everything...got fuel, got spark, good ecu, good distributor(went through 3), timing on top dead, ...i also cheked compression and it seemed a bit low. 120 on 1 and 140 on 2. i didn't bother checkin the other 2. i know it can't be the rings, cuz i just rebuilted the bottom end, or could it?
Old 11-17-2003, 11:16 AM
ej1civic's Avatar
Default Re: car won't start, need help (geezer06)
120 and 140 is way too low.
Old 11-17-2003, 11:18 AM
Unceasing Measure
Archidictus's Avatar
If you indeed "just rebuilted" the bottom end, it very well could be the rings...especially if you do everything as well as you spell.
Old 11-17-2003, 07:30 PM
Snail Tuning's Avatar
u need to check all 4 to get a good idea of what is going on. also did u lower the compression ration when i rebuilt the bottom? also did u use synthetic oil right after the rebuild? and how many miles are on the bottom end sense the rebuild? we need more info inorder to help
Old 11-17-2003, 07:31 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: car won't start, need help (bmcc72)
if it seems like it doesn't have enough power to start, try jumping/chargint he battery first
eghatch515
10-08-2008 08:07 PM
juanb
08-24-2004 06:50 PM
Quick Reply: car won't start, need help
