trail of white smoke = ???
Old 05-29-2002, 03:36 PM
sushibug's Avatar
Default trail of white smoke = ???
if im running rich it should be black smoke right?
if im burning oil it will smell really bad and its blue smoke right?
if its greyish smoke and odorless its coolant burning right?
at idle... i noticed smoke coming from under my hood. im not overheating though. under hard acceleration on the freeway theres a big trail behind me... the cars actually slow down so they can see.
Old 05-29-2002, 03:46 PM
SiRkid's Avatar
Default Re: trail of white smoke = ??? (sushibug)
UH OH!!! time for a rebuild... blown head gasket?? but im thinking blown piston and block.but i could be way off.
Old 05-29-2002, 03:47 PM
inspyral's Avatar
Could it be the seals in the turbo?
Old 05-29-2002, 03:51 PM
Cramerox's Avatar
Default Re: trail of white smoke = ??? (inspyral)
do you see any fluids of anykind leaking?
Old 05-29-2002, 04:21 PM
.nate's Avatar
I believe bad turbo seals will produce blackish smoke... sounds like a headgasket to me... You overheating at all or loosing any coolant?
[Modified by TheFLY, 7:22 PM 5/29/2002]
Old 05-29-2002, 04:33 PM
sushibug's Avatar
Default Re: trail of white smoke = ??? (TheFLY)
no overheating at all. my temp gauge never reaches halfway. radiator fluid is the same level as its been for the last few months.
so... what could it be? my idle seems fine so im really clueless.
edit: erm, while removing the pipe w/ the filter attached to it, i saw a tiny puddle of oil where the silicone and compressor meet. if the other side was leaking... wouldnt it be burned out the exhaust?
[Modified by sushibug, 1:34 AM 5/30/2002]
Old 05-30-2002, 06:45 AM
SiRkid's Avatar
that= bad!!
Old 05-30-2002, 07:02 AM
Ri5e's Avatar
sounds like your turbo went bad.
Old 05-30-2002, 10:19 AM
sushibug's Avatar
Default Re: trail of white smoke = ??? (BG Boost)
i checked the compressor side of the turbo. it spins nicely... will keep spinning when i let it go. it also doesnt have any shaft play still.
Old 05-30-2002, 11:02 AM
apexii's Avatar
Is the smoke occuring during acceleration, or after?
I had a problem where my head lifted a bit off the gasket, and I would only get clouds of white smoke after acceleration, completly off the gas pedal. It would occur during the transition from boost to vacuum, coolant would get sucked into the cylinders and smoke like mad!
A retorque of my copper gasket fixed it, although it did score the cylinder walls a bit...
Old 05-30-2002, 11:09 AM
sushibug's Avatar
Default Re: trail of white smoke = ??? (apexii)
either way my coolant should be milky right? its the same level and its the same nasty azz green color.
Old 05-30-2002, 11:19 AM
wonny's Avatar
Rebuild the turbo - oil in the piping is not good.
Do you have any oil gauges? If I were you, I would be watching your oil pressure/levels and coolant levels.
My guess is that you are just burning the oil in your turbo. Sounds like what happened to me - I had to get the O-rings in the turbo redone.
Dave
Old 05-30-2002, 11:32 AM
sushibug's Avatar
Default Re: trail of white smoke = ??? (wonny)
i know a few 3000gt vr4s that have been spitting 4x more oil into their intake piping them me. they've been running on the same turbo for quite some time now. also, if i was burning oil why cant i smell it?
Old 05-30-2002, 12:08 PM
apexii's Avatar
No. The coolant was not mixing with the oil in my case, just seeping into the cylinders under vacuum.
Old 05-30-2002, 02:12 PM
SiRkid's Avatar
coolant , milky???? isnt that bad?
what turbo do yu have(garret etc)?
Old 05-30-2002, 03:04 PM
JJ-Built's Avatar
you are in denial, do your self a favor and pull the motor apart. white smoke most likely it's a burnt piston. perform a leak down test is the best way to eliminate uncertainty..........
jdmek2277
10
12-13-2007 10:54 AM
EtherEG93
09-17-2005 08:18 PM
92LsTegra
08-19-2004 06:42 PM
immortal
11-03-2001 03:23 PM
veejay
06-29-2001 01:55 PM
Quick Reply: trail of white smoke = ???
