How to: Valve seal removal
Old Apr 25, 2007 | 11:40 PM
amy's Avatar
amy
Default How to: Valve seal removal
I was in the process of getting ready to finish up my head and when I began to do my valve seals, I went to HT to look up how to do it..... and came back with absolutely nothing. So after conferring with several other people I eventually came up with my own way to do it.
You will need:
-heat gun or I guess a torch, whichever does it for you
-pliers, I found that my needle nose ones worked good
Hi I'm your valve seals
I would like to come out
Heat the seals with your heat gun.
Now take your pliers and work your magic
If you can't get it off, try heating it some more. It's ok to burn them a tiny bit, I won't tell anyone
This is what they'll look like when you are done
mmm clean and yummy
Not too difficult if a girl can do it
Modified by amy at 3:50 AM 4/26/2007
Old Apr 25, 2007 | 11:48 PM
Mr.EM1_EK's Avatar
Default Re: How to: Valve seal removal (amy)
nice info
Old Apr 25, 2007 | 11:50 PM
skip.two's Avatar
haha go amy! nice write-up
Old Apr 26, 2007 | 05:26 AM
sicones's Avatar
Default Re: How to: Valve seal removal (skip.two)
now..how do you put them back on??
Old Apr 26, 2007 | 06:09 AM
Hybrid96EK's Avatar
Default Re: How to: Valve seal removal (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">now..how do you put them back on?? </TD></TR></TABLE>
With a special tool...
Old Apr 26, 2007 | 06:33 AM
sicones's Avatar
Default Re: How to: Valve seal removal (Hybrid96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK &raquo;</TD></TR><TR><TD CLASS="quote">
With a special tool... </TD></TR></TABLE>
ok...well let's see the special tool being used
Old Apr 26, 2007 | 07:01 AM
Sleepy_Red_hatch's Avatar
did anyone say "tool" ?
Old Apr 26, 2007 | 09:52 AM
unusual71's Avatar
Amy your funny. the "its ok i wont tell anyone" part made me lol. thanks.
oh and good write up, woulda been funnier if you woulda used your blowdryer or something for a joke though
Old Apr 26, 2007 | 11:42 AM
crxforum's Avatar
Default Re: (unusual71)
I would of just put the head in your easy bake oven and heated them up that way.
CRX Forum
Old Apr 26, 2007 | 12:14 PM
amy's Avatar
amy
a 12mm deep and muscles
Old Apr 28, 2007 | 08:33 PM
SOHCEK-Turbo's Avatar
How long did it take you to remove all the valve seals?? Im considering to do this when I pull my head in a few months after I smog and get ready for a head build instead of taking it in somewere. Are you going with any aftermarket valvetrain??
Nice writeup!
Old Apr 28, 2007 | 08:44 PM
amy's Avatar
amy
Default Re: How to: Valve seal removal (SOHCEK-Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCEK-Turbo &raquo;</TD></TR><TR><TD CLASS="quote">How long did it take you to remove all the valve seals?? Im considering to do this when I pull my head in a few months after I smog and get ready for a head build instead of taking it in somewere. Are you going with any aftermarket valvetrain??
Nice writeup! </TD></TR></TABLE>
it took me about an hour or so...
and yes I'm using new OEM valve seals but supertech springs and retainers
Old Apr 29, 2007 | 09:28 AM
sauceja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy &raquo;</TD></TR><TR><TD CLASS="quote">
a 12mm deep and muscles </TD></TR></TABLE>
I found a 10mm deep and a rubber mallet works as well. Tap them lightly until you hear/feel solid so you know they are seated fully. And I use an adj. pliers also do not use heat.
Modified by sauceja at 12:03 PM 4/29/2007
Old Apr 29, 2007 | 09:33 AM
EJ1 wilcox's Avatar
Default Re: How to: Valve seal removal (sauceja)
I never use a heat gun. I just grab and twist. They will pop off if you work them back and forth a bit.
Old Apr 29, 2007 | 11:56 AM
amy's Avatar
amy
Default Re: How to: Valve seal removal (EJ1 wilcox)
well apparently i suck and can't get them off without heat
Old Apr 29, 2007 | 12:11 PM
EG-Honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy &raquo;</TD></TR><TR><TD CLASS="quote">well apparently i suck </TD></TR></TABLE>
Old Apr 29, 2007 | 12:19 PM
sageuvagony's Avatar
Default Re: How to: Valve seal removal (EG-Honda)
Now we have EG-Honda????
nengx07
Feb 7, 2009 12:18 PM
vinuneuro
Sep 16, 2007 07:03 AM
Red D Dragon
May 5, 2005 10:16 AM
1.8EG-T
Dec 14, 2003 02:56 PM
kyle h.
Jan 27, 2003 08:07 PM
