Confused on setting timing.
Old Apr 15, 2007 | 10:28 AM
invisible's Avatar
Default Confused on setting timing.
I have the gun set at 16º, am I supposed to line it up with the one in the middle of the group of 3? Or is am is it supposed to be at 0º and line it up with the middle?
EDIT:
Ok found my problem I guess, now how do I fix it...
When I'm at the red mark the cams are up side down?
Now when the cams are right, the crank pulley is off...
Modified by cheesee at 7:12 PM 4/15/2007
Old Apr 15, 2007 | 12:31 PM
invisible's Avatar
Default Re: Confused on setting timing. (cheesee)
right now i have it set at 16º and its in the middle of the group of 3. this is the gun im using http://www.sears.com/sr/javasr...e=Yes
Old Apr 15, 2007 | 02:16 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
There are 2 sets of marks on the crank pulley. A single white mark to indicate top dead center on the #1 piston, and 3 red marks to indicate 16 +/- 2 degrees before top dead center (BTDC). On most inductive timing lights, you would use the 3 red marks (the middle one being 16), but since you have a gun with advance, you can do it 2 different ways, whichever one you like.
Either:
1) Set the gun to 16 degrees advance and use the single white mark, or
2) Set the gun to 0 and use the three red marks.
Whichever one you feel comfortable with. Or you could do it both ways as a double-check after you set it with one method.
Old Apr 15, 2007 | 02:41 PM
invisible's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">There are 2 sets of marks on the crank pulley. A single white mark to indicate top dead center on the #1 piston, and 3 red marks to indicate 16 +/- 2 degrees before top dead center (BTDC). On most inductive timing lights, you would use the 3 red marks (the middle one being 16), but since you have a gun with advance, you can do it 2 different ways, whichever one you like.
Either:
Whichever one you feel comfortable with. Or you could do it both ways as a double-check after you set it with one method.</TD></TR></TABLE>
Why is that i cant get it in the middle when i have the gun set at 0? i never took off the dizzy but i did take out the cam and just pushed off the timing belt.
Old Apr 15, 2007 | 04:12 PM
invisible's Avatar
Default Re: (cheesee)
Check out the first post....edited with pictures/problem
Old Apr 15, 2007 | 05:44 PM
invisible's Avatar
Is this where it's supposed to be? Just wana make check for sure, hate putting the damn belt on lol..
Old Apr 15, 2007 | 06:06 PM
RJonathan's Avatar
yup thats how its suppost to be
Old Apr 15, 2007 | 07:17 PM
Community Builder
looks like the belt was off by a few teeth the way you had it before.
Old Apr 15, 2007 | 07:35 PM
invisible's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">looks like the belt was off by a few teeth the way you had it before.</TD></TR></TABLE>
Yeah it was, luckly I didn't drive it atleast
Need to tighten up the tension on the belt some how. the intake side is pretty loose, i can slide it back and forth on the cam gear.
shesinmyroom
11
Jun 7, 2012 08:07 PM
ekpilot
Jan 22, 2009 07:42 PM
invisible
21
Apr 17, 2007 02:22 PM
Zaakro
Mar 29, 2007 07:08 PM
powerfulperformance
Oct 20, 2003 04:58 AM
