Need help using a sears timing gun with the degree dial!!!!
Old Oct 19, 2003 | 07:28 PM
powerfulperformance's Avatar
Default Need help using a sears timing gun with the degree dial!!!!
I just wanted to make sure i'm using this gun right. I'm trying to set my timing to 16 degre timing. Do i put the dial on the timing gun to 16, then line up the crank unit it is at the mark in the middle? I know that i have to jump the ecu already.
Old Oct 19, 2003 | 08:30 PM
SPOONfdEK's Avatar
Default Re: Need help using a sears timing gun with the degree dial!!!! (powerfulperformance)
um. i have the same timing gun and the way ive always done it is you leave the dial at zero. then jump the ecu and put line up the 16 deg. line with the triangle on the timing belt cover .
Old Oct 20, 2003 | 04:58 AM
JimBlake's Avatar
The 14/16/18 degree marks on the crank pulley are for you to use if your timing gun doesn't have the advance dial feature. So set the dial at zero & adjust to those marks.
Or...
Set the dial at 16 degrees and look for the TDC mark, the one all by itself. This should give you the same result. The dial on your timing gun is handy if you want to set something other than stock, or if you've got a crank pulley without the 14/16/18 marks.
98bucket
Nov 21, 2010 03:57 PM
baphomet
May 31, 2005 12:52 PM
JDMTurboCivic11
May 1, 2005 08:32 PM
projectTeG
Mar 31, 2005 05:17 PM
EKB18BPR3
Nov 30, 2003 10:36 AM
