couple questions for those more experienced. turbo sizing.
Old Apr 14, 2007 | 11:45 AM
xDicktonesx's Avatar
Default couple questions for those more experienced. turbo sizing.
alright, first and foremost the power goal is 475whp to 500whp on 93 octane gas.
the set up is as follows
B18B GE sleeved 84mm
PR3 head w/ 5 angle stock sized valves
stock 89mm crank polished/balanced
eagle H beam rods
pistons yet to be determined ~9:1 CR*
custom top mount manifold by rmf designed to retain a/c
hogged out "R" manifold or whatever i can get a deal on*
CTR cams
obd1 crome pro realtime
asterick items are not yet in my closet.
now, with that out of the way, so i can possibly be helped, i am having a little trouble with turbo sizing.
i am thinking the PT SC61 will be about the size i need and will make about the power i want at around 18-20psi.
does anyone have any BETTER suggestions? im not a cheapskate, but i would like to keep the price under 1800 bucks or so for the turbo. the SC61s float around here for 800 bucks so that is attractive.
also, what size wastegate flange should i have him put on the manifold? is 38mm enough? i think i saw a 42 or 45mm tial as well....
going into 00 civic coupe with Y1 b16 cable tranny with quaife LSD not that those matter.
Old Apr 14, 2007 | 12:11 PM
Schister66's Avatar
Man U FTW
I would go w/ a 44mm wastegate on the topmount since your turbo is going to be fairly large...
Also for a turbo choice, its a bandwagon choice, but a GT35R would fit your needs....i'm interested to see what other turbos are suggested...
Old Apr 14, 2007 | 12:12 PM
tony413's Avatar
read my post an link also if you need additional such as sizing an exact turbo for your car and sizing an intercooler PM me with your question and info of purpose for car.
https://honda-tech.com/zerothread?id=1920545
to answer 66's question i like the borg warner S258, S366, S463, Holset HX40/35 hybrid, and a few others
Old Apr 14, 2007 | 12:18 PM
Default Re: (tony413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">read my post an link also if you need additional such as sizing an exact turbo for your car and sizing an intercooler PM me with your question and info of purpose for car.
to answer 66's question i like the borg warner S258, S366, S463, Holset HX40/35 hybrid, and a few others </TD></TR></TABLE>
purpose for the car is simple. its a toy. a toy geared more for the strip. i dont want it to be totally undrivable and id like it to be into boost by 3k and make peak power at or BEFORE 8500rpm. not quite sure if that is totally un realistic.
B20TDC2's Avatar
sc 61 will get ya there. i got 426hp and 322trq at 18.5 psi. and go with thw 44mm wastegate
here is a graph
Old Apr 14, 2007 | 12:27 PM
Default Re: (B20TDC2)
it almost looks like i might want a little more turbo. i dont want to be at my limit at 500. i want my snail and my bottom end to be kicked back and relaxed sipping their beverages of choice at boost somewhere in the mid 20s at more than 480whp.
Old Apr 14, 2007 | 12:34 PM
B20TDC2's Avatar
Default Re: (xDicktonesx)
when i sold the car the new owner got a new sc61 (mine was about out of it) and made right about 500 out of it on pump and 655 on race gas @27-28psi. the turbo has the capability.
tony413's Avatar
with a S258 he could get more HP at a lower psi because the efficenticy is uber more the S364 would also blow that out the water an the holset hybrid if you wanted could push 30psi(if wanted) at about 3.5k to 4.5k BUT will start chokin at around 8k i believe.
to the OP: remember CFM's get you power and different turbos supply different CFM's at different psi's
Old Apr 14, 2007 | 12:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">with a S258 he could get more HP at a lower psi because the efficenticy is uber more the S364 would also blow that out the water an the holset hybrid if you wanted could push 30psi(if wanted) at about 3.5k to 4.5k BUT will start chokin at around 8k i believe.
to the OP: remember CFM's get you power and different turbos supply different CFM's at different psi's </TD></TR></TABLE>
borg warner S258 huh? where can one of these be had?
Old Apr 14, 2007 | 12:43 PM
tony413's Avatar
bullseyepower.com dealer an great info
timsturbos.com/bullseye_power_products.html
theres other places with different prices look under the links at bulls eye
Old Apr 15, 2007 | 11:58 AM
more opinions. checked out the borg warner selections. look good.
Old Apr 15, 2007 | 12:06 PM
vtecspeed1320's Avatar
Shooting Star
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDicktonesx &raquo;</TD></TR><TR><TD CLASS="quote">purpose for the car is simple. its a toy. a toy geared more for the strip. i dont want it to be totally undrivable and id like it to be into boost by 3k and make peak power at or BEFORE 8500rpm. not quite sure if that is totally un realistic. </TD></TR></TABLE>your meaning starting boost at 3k? or full boost by 3k? I seen somewhere else you dont want your turbo to be maxed at 480...well a t3/67 or t4/67 would be 2 of my choices.
golf-mk3
Jan 19, 2011 02:23 PM
an1mositySID
Jul 9, 2008 04:19 AM
Mr.Hankey
Sep 13, 2006 08:23 PM
VtecKiDD
Apr 19, 2006 02:15 PM
lilbluehatch1
May 2, 2005 08:39 PM
