Turbo ls Questions
Old Apr 17, 2005 | 09:30 PM
lilbluehatch1's Avatar
Default Turbo ls Questions
allright guys im goin to turbo my ls in a couple of weeks and i have one small problem i have no clue what turbo and some other things to go with my ideal horsepower goal is 350 tuned...
my setup as of now
b18b
block
Block is currently at machine shop getting hottanked honed and miled..
JE 9:1 pistons
Eagle H-beam rods
Golden Eagle Block Guard
micropolished and balanced crank
Head
p&p head
ferrea valves
springs and retainers ???
cams jg engine dynamics or crower ???
99 gsr tranny
exedy clutch
gsr lightend flywheel
Turbo Setup
Fab works equal length manifold
Fab works 3 in DP
jrc ic
injectors ?
tial wastegate what size?
tial bov what size?
fuel pump what size?
TURBO---what kind and size ?
Tuning
Neptune or power fc
Tuned by jack at p1
i will go ahead and thank you for lookin at my thread and hopefully responding with some good info
(and yes i searched)
Modified by lilbluehatch1 at 11:31 PM 4/18/2005
Old Apr 18, 2005 | 05:26 AM
Blue98Ex's Avatar
Default Re: Turbo ls Questions (lilbluehatch1)
My boy has a similar setup exept he has a stock head. Hes running an t3/SC61 and he put down 417whp and 340tq and ran a 12.9 at 114mph on pump gas and shitty *** street tires in a 95 coupe with AC and full interior. I think the SC61 is really nice on this setup and it pulls like a mother when it hits full boost. Ne ways if u want a tial BOV its gonna be a 50mm BOV and i think the tial 38mm or 40mm wastegate would be good for u. The walboro 255 fuel pump should do the job and injectors i would get maybe like 720cc or 780cc just so u have a little room for upgrade and itll be plenty for u if u want 350hp. Hope this might help u some.
Old Apr 18, 2005 | 02:32 PM
Default Re: Turbo ls Questions (Blue98Ex)
yea it helps thanks alot anyone else ?
Old Apr 18, 2005 | 03:49 PM
Dampach1's Avatar
Depends on your goals........ In my experience, If your only going for 350 then you would want the best daily driving turbo you can get. I would go for something along the lines of a basic t3/t4 or sc34. That would get you the power you want and would have in my eyes the best overall driveabilty.
Old Apr 18, 2005 | 06:20 PM
Default Re: Turbo ls Questions (Dampach1)
yea honestly im not worried about daily drivablity i mainly drive it on the weekends and pretty days... my goals are 350 plus lol
Old Apr 20, 2005 | 06:09 PM
come one guys noone >?
Old Apr 20, 2005 | 06:20 PM
Makdaddynuge's Avatar
well do you want something with quick spool or something that gives you a little lag so its easier when just driving around normal? Whats your price range?
Old Apr 20, 2005 | 07:38 PM
Dunc's Avatar
BCICAN
Default Re: (Makdaddynuge)
Injectors: 550 will be just fine for 350whp. But I would get like 650-750's for room to spare.
Wastegate: A 40mm Tial will do.
BOV: Not sure
Fuel Pump: Walboro 255
Springs & Retainers: Definitely replace....Skunk 2, Crower, its up to you
Turbo: A T3/T4 would be plenty
Cams: I hear stock GSR cams are good, I have the skunk 2 turbo cams and like them. It's your choice.
I'm running 375whp on a T3/T4 .57 with 550cc's @ 78% duty cycle....click this link and scroll to the bottom. You can see dyno curves and a list of all the parts that are on the car..... http://www.cardomain.com/memberpage/785908
i want somethin with semi quick spool lets say between 4-5k full boost but will produce alot of power to get near my goal of 350+ i wanna spend around 700 for the turbo
Old Apr 20, 2005 | 08:36 PM
Dunc's Avatar
BCICAN
Default Re: (lilbluehatch1)
with no cat and my 3" downpipe, I start spooling the T3/T4 .57 around 3200rpms. Hit full boost around 4000-4200.
Old Apr 20, 2005 | 10:46 PM
t3/t4 57 trim would be good
Old Apr 21, 2005 | 02:49 AM
BoostedCivicSedan's Avatar
I run a straight LS in my car with a built bottom end (8.7:1CR) and the head is stock with the exception of cams... I am running an SC61S with the .63 ar 4 bolt housing, and t350 stage 5 wheel... My car sees full boost (about 20psi) by 4600 rpm..... I love my SC61
Old Apr 21, 2005 | 07:32 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Makdaddynuge &raquo;</TD></TR><TR><TD CLASS="quote">t3/t4 57 trim would be good</TD></TR></TABLE>
this is what i am running. the sc34 will also be good. you shouldnt need any more turbo than these two to achieve your goals.
dont forget to get an aftermarket intake manifold, especially if u are doing cams so that they can breathe a lil better. i was too broke to go aftermarket so i fabbed a shorter runner b16 manifold to my ls.
you can do 350whp on 550's, but since you have a worked motor, im sure you will want more soon. its better to get the injectors a lil bigger now.
also i think the jrc intercoolers are only good for 350ish, and as i said before it might be a better idea to overplan now and give room to expand later
Old Apr 21, 2005 | 09:10 AM
SpoonyGSR's Avatar
I hate rap music
Sc34.. nice street turbo..
Old Apr 24, 2005 | 04:36 PM
ive made my turbo selection of using a sc61 now i need to figure out the rest of the stuff... any other suggestions ?
Old May 2, 2005 | 08:39 PM
new setup consists of a hint of vatack!!!
SSBPGSR's Avatar
tial 50mm BOV
tial 38mm WG
monday loves men
mando_eg2
Sep 3, 2013 08:12 AM
jakoh77
Mar 4, 2012 07:17 PM
golf-mk3
Jan 19, 2011 02:23 PM
94c1v1cex
Dec 23, 2007 01:38 PM
DFW
May 1, 2005 09:18 PM
