Need speedo help
Old Apr 9, 2007 | 03:46 PM
Diet coke boii's Avatar
Default Need speedo help
While driving my needle jumps all over and sometimes doesnt move untill I reach a steady speed.I searched but came up with nothing.
Old Apr 9, 2007 | 03:48 PM
DohctorVtec's Avatar
Default Re: Need speedo help (Diet coke boii)
Check your speedo sensor plug. It is on the tranny behind the starter. Make sure it is plugged in all the way and not loose.
Old Apr 9, 2007 | 03:51 PM
Checked and its fine.
Old Apr 9, 2007 | 04:23 PM
Default Re: (Diet coke boii)
Anyone?
Old Apr 9, 2007 | 04:52 PM
rhdek's Avatar
sensor's probably bad... common problem with honda
Old Apr 9, 2007 | 04:58 PM
B18cFreak's Avatar
mine does that 2. its very tempermental. i was planning on replacing the guage cluster with a jdm si-r and cross my fingers hoping that its the guage cluster. but i thought it may be a short in the wires if its not the sensor.
Default Re: (rhdek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhdek &raquo;</TD></TR><TR><TD CLASS="quote">sensor's probably bad... common problem with honda</TD></TR></TABLE>
thanx
Old Apr 9, 2007 | 05:07 PM
JDM-EJ1's Avatar
Trying cleaning it before you replace it.
Old Apr 9, 2007 | 06:35 PM
tdizz07's Avatar
Default Re: (JDM-EJ1)
that happened to me too, but i havnt fixed it yet
Old Apr 9, 2007 | 06:37 PM
si0385.'s Avatar
Default Re: (rhdek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "rhdek" &raquo;</TD></TR><TR><TD CLASS="quote">sensor's probably bad... common problem with honda</TD></TR></TABLE>
x2
Old Apr 9, 2007 | 06:52 PM
Default Re: (si0385.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Trying cleaning it before you replace it.</TD></TR></TABLE>
will do
Old Apr 9, 2007 | 07:26 PM
Cleaned it and no luck
Gonna buy sensor tomorrow
Old Apr 9, 2007 | 07:30 PM
ke98248's Avatar
tell me if it works
Old Apr 9, 2007 | 07:34 PM
Default Re: (ke98248)
Will do
Old Apr 10, 2007 | 02:28 PM
Works fine after new sensor
Thanx guys
Old Apr 11, 2007 | 01:25 PM
B18cFreak's Avatar
how much is the sensor? ima have 2 get 1 2 then.
TeamEK
May 20, 2009 08:34 AM
EJ8-Yao
Engine Management and Tuning
Apr 21, 2009 05:28 PM
burgandybeast
Nov 2, 2007 02:30 PM
x8_andrew_8x
Mar 11, 2006 06:15 AM
APEX CRX
Jul 27, 2005 01:38 PM
