help i have a cluster glitch
I have ek civic and my cluster mphs goes up and down even if am not driving. I was wondering if i need to change my speed sensor, and where is that located at?
Also i have two clusters a si and my stock one and when i put each in my car the Fuel/Temp Gauge dosent work for both, do you guys know what might be the problem?
Re: help i have a cluster glitch
check your wires on the speed sensor and it's locate at the tranny.
on the fuel/temp i would also check for the wires and the sensor.
i had the same problem about a month ago. pull out the plug that goes to the speed sensor and try cleaning it. mines was going crazy because it had water when i went through a flood. after i cleaned it the code went away and the speedometer started to work normal again.
doubleoazn03
05-29-2012 03:02 PM
bboyjimpy
16
03-16-2008 06:28 PM
