Checking speedometer
Old Jul 27, 2005 | 09:06 AM
APEX CRX's Avatar
Default Checking speedometer
anyone know the correct way of checking the speedo? my ITR cluster's speedo is not working. no codes, I heard you can manually push the needle to around 100mph and it should slowly wind back to 0 mph to see if the needle is sticking. anyone else know if there is a better way of checking?
Old Jul 27, 2005 | 09:12 AM
gsr dood's Avatar
Default Re: Checking speedometer (APEX CRX)
make sure everything is hooked up correctly in the back of the cluster. also check the VSS vehicle speed sensor on the tranny to make sure its still working.
Old Jul 27, 2005 | 09:21 AM
JDM-EJ1's Avatar
Default Re: Checking speedometer (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">make sure everything is hooked up correctly in the back of the cluster. also check the VSS vehicle speed sensor on the tranny to make sure its still working.</TD></TR></TABLE>
Exactly, the cables in the back of the cluster are probably okay. I would try checking the VSS and making sure it's in good, working condition.
Old Jul 27, 2005 | 11:42 AM
APEX CRX's Avatar
Default Re: Checking speedometer (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly, the cables in the back of the cluster are probably okay. I would try checking the VSS and making sure it's in good, working condition.</TD></TR></TABLE>
OK, I checked for power and ground on the VSS already. how do you go about checking the signal and checking the VSS itself? anyway to manually check that its giving a pulse?
Old Jul 27, 2005 | 12:44 PM
gsr dood's Avatar
thhis can be a little tricky because u cant use an ohm meter to get a signal from the vss while the car is stationary, i would borrow a friends VSS that u know works or possibly put the front end up and jacks and check for a signal. you should also trace the wiring. good luck.
Old Jul 27, 2005 | 01:32 PM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">thhis can be a little tricky because u cant use an ohm meter to get a signal from the vss while the car is stationary, i would borrow a friends VSS that u know works or possibly put the front end up and jacks and check for a signal. you should also trace the wiring. good luck. </TD></TR></TABLE>
OK, I also heard you can maybe take the VSS out and manually spinning it to see if the speedo will move?
thanks for the help guys
Old Jul 27, 2005 | 01:38 PM
Lan's Avatar
Lan
Yeah check on that. It could be that the teeth on the SS are damaged making it impossible for you to get a reading.
96 EX
13
Jan 3, 2007 12:22 PM
ugly rex
Jan 1, 2007 11:19 PM
civicDX2178
May 3, 2006 06:43 AM
mkinpwrat12g's
14
Aug 22, 2005 09:10 AM
HULKHATCH10
15
Jul 12, 2005 09:27 PM
