Need Engine Info On d15b
Hey guyz im pretty noob when it comes to civics so I Need Some Help!!!Previously I purchased a engine from some mechanic Basically it was worth ****!!!
Im about to rebuil the whole engine with my dad and was noticing that engine block is D15B which from what i heard VTEC But It aint I have a normal head NonVTEC on it!!My Q is that i was wondering if that is a VTEC Block And if i can place A VTEC head On It And what are the diffirences on them when it comes to sensors!!! My Car is A 93 Honda CIVIC LX i think the previous motor Was D15B2 or B7 !! I dont know !! Anyways Any help would be appreciated
I don't know about d15b's, but I do know that some of the VTEC engines on 92-95 civics didn't have VTEC on the valve cover... are you sure it's a non-VTEC head?
Absolute best way to check is to pop the valve cover and look for the VTEC lobe.
D15B7's are non-vtec,
you can change the B7 head for a vtec head (Z6) which will fit perfectly, making a D15Z6
Heres a thread about the swap:
https://honda-tech.com/zerothread/554053
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fdavie »</TD></TR><TR><TD CLASS="quote">Absolute best way to check is to pop the valve cover and look for the VTEC lobe.</TD></TR></TABLE> how about you post a pic of your engine, mainly of the valve cover area so we can see if it gotz a VTEC solenoid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCsleeper »</TD></TR><TR><TD CLASS="quote">a D15B is a jdm 1.5 vtec motor </TD></TR></TABLE> Not all were VTEC, the only D15B Vtec is the 0BD1 motor. I believe there are three versions of this motor. I think its like 2 versions are OBD0 non-VTEC, and one OBD1 VTEC.
https://honda-tech.com/zerothread?id=1916210
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">d15b = every d15 in japan
usdm d15z1 = d15b in japan
d15 version of d16z6 = d15b in japan
usdm d15b7 = d15b in japan
usdm d15b8 = d15b in japan
obd2 3stage vtec = d15b in japan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1916210
i just purchased a vtec to swap with. also does anyone know if i can still use the same distributor from my car on the new D15b VTEC one!!!! Thanx hey sorry but i really dont know hot to post pics!!!!
