Type-R lsd install question
Old Mar 28, 2007 | 01:24 PM
enasnitsi's Avatar
Default Type-R lsd install question
I'm installing a Type-R lsd into my 2000 Civic SI. I have a couple of questions on it. I had assumed you could use the stock ring gear but it obviously does not fit so I am just wondering if you have to get the type r ring gear? Also, since I didn't have the right ring gear I installed the differential to check and see what 80mm shim to order. I got it into the case and have it seated all the way down but when I measure the gear side to figure out what shim to order its like .147" of gap. and the shims only got to .0768". Am I just supposed to put a couple of them together to make up the difference or is there another problem. Also I swapped the tapered roller bearings for the enclosed ball bearings.
Any help would be greatly appreciated.
Thanks
Old Mar 30, 2007 | 07:11 PM
enasnitsi's Avatar
Default Re: Type-R lsd install question (enasnitsi)
If anyone could point me in the right direction to find some more information. I've been searching and have come up with no good answers. Any info. would be greatly appreciated
Old Mar 30, 2007 | 08:05 PM
sauceja's Avatar
https://honda-tech.com/zerothread?id=1918178
https://honda-tech.com/zerothread?id=1085206
https://honda-tech.com/zerothread/1922582
https://honda-tech.com/zerothread?id=795700
https://honda-tech.com/zerothread?id=239927
http://www.ff-squad.com/tech/temp/Bgears.htm
jceltalentoso
Transmission & Drivetrain
May 13, 2014 09:05 PM
mach3lude
Aug 29, 2011 07:18 AM
InfamousDC2FI
May 13, 2006 07:59 PM
Shmaa
May 24, 2005 12:52 AM
d_mina
Oct 13, 2003 10:06 PM
