chipped ecu throwing vtec code on none vtec motor
Old Mar 25, 2007 | 09:40 PM
slowr6's Avatar
Default chipped ecu throwing vtec code on none vtec motor
fixed
Modified by slowr6 at 7:18 PM 4/1/2007
Old Mar 26, 2007 | 07:04 AM
beanMosheen's Avatar
Did you disable vtec in the code?
Old Mar 26, 2007 | 07:21 AM
mmuller's Avatar
Mad Scientist
Default Re: (beanMosheen)
ill answer for him
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beanMosheen &raquo;</TD></TR><TR><TD CLASS="quote">Did you disable vtec in the code?</TD></TR></TABLE>
mmm. no
Old Mar 26, 2007 | 10:09 AM
slowr6's Avatar
Actually i did, thats why i dont understand it throwing a vtec code
Old Mar 26, 2007 | 12:12 PM
99B16Si's Avatar
there was probably hardware added to the board for vtec. the software is not going to bypass this. remove the hardware components from the system board and it will fix the problem
Old Mar 26, 2007 | 12:28 PM
slowr6's Avatar
It didnt throw a code util i chipped it.
Old Mar 26, 2007 | 01:11 PM
99B16Si's Avatar
exactly
Old Mar 26, 2007 | 01:15 PM
mmuller's Avatar
Mad Scientist
Default Re: (99B16Si)
did you just chip it or added vtec also?
Old Mar 26, 2007 | 01:17 PM
slowr6's Avatar
Why would i add vtec to a ls. No i didnt.
Old Mar 26, 2007 | 06:47 PM
Cimburke23's Avatar
he already removed the vtec hardware
Old Mar 27, 2007 | 04:51 PM
Tomdata's Avatar
Default Re: (slowr6)
why not try making another program and disabling the vtec again to see if it was a bug in that particular bin file. What software are you using to burn the chip and what chip burner are you using?
ghettoSi
Jan 11, 2008 11:39 PM
JunY
Honda S2000
18
May 17, 2005 09:37 AM
wfo
Feb 25, 2005 02:21 PM
endlesswinterco
Jan 3, 2004 10:34 AM
Hondasaurs
Apr 25, 2003 07:30 PM
