chipped ecu throwing vtec code on none vtec motor
Did you disable vtec in the code?
Re: (beanMosheen)
ill answer for him
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beanMosheen »</TD></TR><TR><TD CLASS="quote">Did you disable vtec in the code?</TD></TR></TABLE> mmm. no |
Actually i did, thats why i dont understand it throwing a vtec code
there was probably hardware added to the board for vtec. the software is not going to bypass this. remove the hardware components from the system board and it will fix the problem
It didnt throw a code util i chipped it.
exactly
Re: (99B16Si)
did you just chip it or added vtec also?
Why would i add vtec to a ls. No i didnt.
he already removed the vtec hardware
Re: (slowr6)
why not try making another program and disabling the vtec again to see if it was a bug in that particular bin file. What software are you using to burn the chip and what chip burner are you using?
