Will Code 9 cause Vtec to malfunction?
Old Apr 25, 2003 | 12:23 PM
Hondasaurs's Avatar
Default Will Code 9 cause Vtec to malfunction?
I have a code 9, 21, and 22. No Vtec. I wired the distributer directly to the ECU. There were two orange/blue wires (OBD1). Would hooking these up wrong cause this?
Old Apr 25, 2003 | 02:17 PM
Mikey3000's Avatar
Default Re: Will Code 9 cause Vtec to malfunction? (ZC_CRX)
code 9 is crank position sensor i believe. code 21 is vtec solenoid and code 22 is vtec oil pressure. i might have those two backwards but vtec will not work with either of those codes present. your car shouldnt even be running right with the code 9.
Old Apr 25, 2003 | 02:44 PM
ScottEK's Avatar
Default Re: Will Code 9 cause Vtec to malfunction? (Salvatore Leone)
It will still run with code 9 but you will be in limp mode, plus your other two VTEC codes, no there is no way you are going to be hitting VTEC. Why are you even trying to go that high with three codes?
Old Apr 25, 2003 | 02:53 PM
raene's Avatar
Default Re: Will Code 9 cause Vtec to malfunction? (beta13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 &raquo;</TD></TR><TR><TD CLASS="quote">It will still run with code 9 but you will be in limp mode, plus your other two VTEC codes, no there is no way you are going to be hitting VTEC. Why are you even trying to go that high with three codes?</TD></TR></TABLE>
Because some people are crazy
Old Apr 25, 2003 | 04:43 PM
Hondasaurs's Avatar
How do I fix the code 9? The engine runs as if nothing was wrong with it, just no vtec.
Old Apr 25, 2003 | 07:30 PM
ScottEK's Avatar
Replace distributor.
FASTESTCB7inQNZ
Nov 18, 2009 06:41 AM
ZC DOHC CRX
May 20, 2009 10:52 PM
ef-hatchcrap
Feb 21, 2009 05:10 AM
