ARP head studs in ls motor
Old Mar 20, 2007 | 10:05 PM
7808's Avatar
Default ARP head studs in ls motor
i got some ARP studs im about to install, head is off bout to put it back on, anyone know a good amount to torque them too? i've read anything from 65-85 ft-lbs so i was go go for 70ish
i think my box was missing instructions, or maybe they jsut figure you know... also what do you guys do for putting the studs in the block, hand tight snug with a allen wrench or what?
lube everthing pretty much but the middle of the stud?
thanks
Old Mar 20, 2007 | 10:18 PM
SiYouLater's Avatar
Default Re: ARP head studs in ls motor (7808)
I think some people use 70-80ft lb's. Also try to blow some compressed air into the threaded holes just in case there is debris in there.
Old Mar 21, 2007 | 12:17 AM
96-EJ6 B18C's Avatar
Default Re: ARP head studs in ls motor (SiYouLater)
Yep, clean the threads, fresh engine oil on the threads that go in to the block, snug with allen wrench, and torque the nuts to 80Lb/Ft using the stock torque sequence. That's how I do them
Old Mar 21, 2007 | 06:14 AM
boosted_EM1's Avatar
Default Re: ARP head studs in ls motor (96-EJ6 B18C)
i was wondering the same thing, is there any difference in the torque specs for a b16? mine are going in this weekend. thanks for the info
Old Mar 21, 2007 | 01:52 PM
7808's Avatar
anyone know what size thread chaser to use for a ls block and where to get one lol
having a hard time getting them clean
Old Mar 21, 2007 | 02:29 PM
wbaldwin_86's Avatar
the thread is a m11 by 1.5... good luck i just had 2 of them strip out
Old Mar 21, 2007 | 02:34 PM
7808's Avatar
Default Re: (wbaldwin_86)
the chaser stripped?
Old Mar 22, 2007 | 04:13 PM
Default Re: (7808)
the treads striped out of the block.
Old Mar 22, 2007 | 07:13 PM
turbodegsi's Avatar
holy **** 80ftlbs seems high
Old Mar 23, 2007 | 04:36 PM
Default Re: (turbodegsi)
it is for Aluminum
Kr4nG
Nov 6, 2009 02:48 AM
ivt-t
Feb 8, 2007 09:15 PM
flip1199
Aug 2, 2005 12:28 PM
dohcter g
Mar 29, 2004 07:43 PM
X2BOARD
May 17, 2002 10:51 AM
