Idea's on why my GT28RS seized on me????
Old Feb 25, 2007 | 08:22 AM
dkboyny11's Avatar
Default Idea's on why my GT28RS seized on me????
I've had this turbo on the full-race stage 1 GT kit on the car for approx 5,000 miles now. I was driving it the other day and the turbo started to act weird, almost like a silicon tube popped off or something. I limped it home about a mile and looked for problems. Well after finding no couplers loose, I removed the air filter. When I tried to spin the turbo it was not spinning as easy as it used to. Not completely seized, but definitely something wrong. I had good oil pressure, and never had signs of any problems before. If you guys could maybe recommend some things to look at before I install my new turbo. Thanks for any help
Modified by dkboyny11 at 9:42 AM 2/25/2007
Old Feb 25, 2007 | 09:01 AM
BoOsTeD C1's Avatar
Do you have your coolant lines hooked up to the turbo?If so what are your sources?
Old Feb 25, 2007 | 09:02 AM
shortyz21's Avatar
Default Re: Idea's on why my GT28RS seized on me???? (dkboyny11)
where is the feed for the turbo taken from?
did u run a restrictor?
pics of drain.
Old Feb 25, 2007 | 09:12 AM
dkboyny11's Avatar
Default Re: Idea's on why my GT28RS seized on me???? (shortyz21)
My oil feed was taken from the brace tee fitting that full-race supplied to be located where the stock oil light sensor was. I originally wasn't sent the restrictor in the beginning and had to send the turbo back to garret because I thought it was leaking through the seals or something. I think was was due to no restrictor. They rebuilt it anyway and sent it back to me. I ran it with a restrictor the second time with no problems. I could always hear the turbo spin forever after shutting the car off. The drain is the one supplied with the full race kit run to a Z10 oil pan. No kinks or anything smooth transitions. Also, I first has a #4 AN oilfeed line, but used a #3 oil feed line with the restrictor after the first problem.
Old Feb 25, 2007 | 10:02 AM
*Boostwerks*'s Avatar
Contact a Garrett distributor, and ask them about they're CHRA replacement program. I just heard about this the other day from Garrett's news letter. If they will replace the CHRA or give credit for a new turbo unless they find a reason that the turbo was improperlly used or taken care of.
Old Feb 25, 2007 | 10:31 AM
dkboyny11's Avatar
Default Re: (Boostwerks.com)
I just found the source to the failure. I had a very tinny piece of silicone stuck in the oil feed line restrictor. Was I supposed to run a filter along the oil feed line???? Has anyone else experienced this before. Man realy sucks that a little piece of silicone F'd my $1000 turbo up. I don't even know if they will be able to fix any part of this thing. I could see broken pieces inside the oil housing on the return side. Mother F'er
Old Feb 25, 2007 | 01:16 PM
rmcdaniels's Avatar
Default Re: (dkboyny11)
I've had that exact problem before, a piece if excess grey silicone from the engine assembly got in there and it destroyed a $1000 ball-bearing turbo. With the tiny little restrictors that the BB turbos like, any little thing will clog it. Since then I used a -4AN line with a ATP restrictor fitting on the turbo and a wire-basket style strainer filter inline. NOS makes a nice aluminum one that fits inline with a -4AN oil feed line. Since then I've had no problems.
Old Feb 25, 2007 | 01:28 PM
hopware's Avatar
Default Re: (rmcdaniels)
Thanks for sharing, that certainly gives me food for thought. Not exactly a scenario that I had considered, but another case of benefitting from others misfortune. None of us are as smart as all of us!
Old Feb 25, 2007 | 01:43 PM
HiProfile's Avatar
On my oil distribution manifolds, I always put a little screen in front of the outlet for the turbo. It goes from 1/4" NPT into a 1/4-1/8" bushing, to the 1/8"-to-AN fitting that I make into a restrictor; the screen is wedged in right before that first bushing, pushed in from the other side of the manifold.
Old Feb 26, 2007 | 02:14 PM
dkboyny11's Avatar
Thanks for the info. I have a GT28RS dual-ball bearing turbo as well. I had a little grey piece of silicone stuck in my .035" restrictor also. Man what a shitty thing to happen. I guess it's just our luck
Old Feb 26, 2007 | 02:16 PM
dkboyny11's Avatar
Default Re: (HiProfile)
Also, a great idea. Thanks for the input, but I think I would feel better with some sort of in-line filter.
Old Feb 26, 2007 | 05:21 PM
dkboyny11's Avatar
Can you show me the exact filter from NOS that you are using on the oil feed line. The only one that I found was a high pressure Nitrous filter(aluminum). Thanks
Old Feb 26, 2007 | 05:36 PM
rmcdaniels's Avatar
That's the one, it has a screen basket filter inside of it, works great as an oil filter for my turbo oil feed. The -4AN filter screws right in to a -4AN oil feed line, and it's easy to open and check the strainer. Here's a pic of it on my motor:
Old Feb 26, 2007 | 08:30 PM
Sprockets's Avatar
I just bought this one:
There's a 10 micron stainless screen inside and -4an ends. It's overpriced, but a nice piece.
Old Feb 27, 2007 | 12:53 PM
dkboyny11's Avatar
thanks again, I just placed my order for the same filter.
Old Feb 27, 2007 | 03:08 PM
eg:R's Avatar
does the oil sandwich plate get filter oil to the turbo???
Old Feb 27, 2007 | 03:47 PM
DRAGLS's Avatar
Default Re: (eg:R)
the golden eagle one does.
Old Feb 27, 2007 | 08:26 PM
Sprockets's Avatar
Default Re: (DRAGLS)
Unfortunately, the oil isn't always filtered no matter where the source is. If the oil filter is operating in bypass, then your turbo is getting unfiltered oil.
G-Auto*Hero
Jun 4, 2009 07:26 PM
boostedcoupe1
Feb 20, 2008 01:55 PM
tcontesh
May 27, 2006 06:47 PM
rubyred
Jan 6, 2006 08:56 PM
kj98r
May 16, 2004 03:16 PM
