vtec engagment point
Old Feb 16, 2007 | 10:45 AM
92dat_lude's Avatar
Default vtec engagment point
on my h22 swap i've installed i/h/e,cam gears, pulleys,,,and i was planning on changing my vtec engagment point but i've heard that it wouldn't be such a great idea...would it be best if i don't mess with it?
Old Feb 16, 2007 | 11:28 AM
Chuckles99SH's Avatar
Default Re: vtec engagment point (92dat_lude)
Get tuned. Dont mess with your engagement point without tuning. Do it right or changing your vtec crossover will mean loss of power.
Old Feb 16, 2007 | 11:34 AM
rickyh22's Avatar
I would say don't mess with any vtec setting because it is bad.... it will make your lude lose power.... if that is wat you want then do it...
Old Feb 16, 2007 | 02:22 PM
mjcloud19's Avatar
^+1
Old Feb 16, 2007 | 02:44 PM
WhiteBB2's Avatar
Default Re: (mjcloud19)
your vtec engagement point was set there by Honda for a reason...
Old Feb 16, 2007 | 03:39 PM
sleepyH22's Avatar
yep yep...
i changed my vtec crossover on my vafc I to l->H is 4700 and HI->lo is 4600..
works great and i run 14.5's at the strip with basic i/h/e and vafc I untuned.
Just for the record, when untuned, you are not to go beyond 300rpms +/- from stock which is 4900, ur tach may say otherwise but it really 4900. soo, just dont go over 5200 or under 4600 i know my typing sucks but i think you should get the point..lol..16hr shift gets tough.lol
Old Feb 16, 2007 | 09:13 PM
GtechPro's Avatar
Default Re: (sleepyH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepyH22 &raquo;</TD></TR><TR><TD CLASS="quote">yep yep...
i changed my vtec crossover on my vafc I to l-&gt;H is 4700 and HI-&gt;lo is 4600..
Just for the record, when untuned, you are not to go beyond 300rpms +/- from stock which is 4900, ur tach may say otherwise but it really 4900. soo, just dont go over 5200 or under 4600 i know my typing sucks but i think you should get the point..lol..16hr shift gets tough.lol</TD></TR></TABLE>
I remember having a similar set-up to the OP's and setting my crossover to 5200 RPM. It yielded decent power up top. I also remember having it at 4600, 4700 and 4800 and it killed the top end. In the end, after a dyno session, I set it back to stock.
Old Feb 17, 2007 | 10:44 AM
92dat_lude's Avatar
Default Re: (GtechPro)
thanks
Old Feb 17, 2007 | 03:06 PM
1GPlusSH's Avatar
Default Re: (92dat_lude)
When you get on a dyno, you need to lower your engagement point to where your torque starts dropping off. Instead of having the dip that some have after minor bolt ons, you'll have a smooth curve where the crossover point is. It won't feel as strong because you won't feel the punch of the vtec, but you will be noticeably faster. When I change mine, I gained 11whp and 25wtq at 5000rpm, but it felt slower because I didn't have that vtec kick. You want that smooth engagement.
Old Feb 17, 2007 | 03:17 PM
md23vtec's Avatar
Default Re: (1GPlusSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GPlusSH &raquo;</TD></TR><TR><TD CLASS="quote">When you get on a dyno, you need to lower your engagement point to where your torque starts dropping off. Instead of having the dip that some have after minor bolt ons, you'll have a smooth curve where the crossover point is. It won't feel as strong because you won't feel the punch of the vtec, but you will be noticeably faster. When I change mine, I gained 11whp and 25wtq at 5000rpm, but it felt slower because I didn't have that vtec kick. You want that smooth engagement.</TD></TR></TABLE>
I agree 100%. I have seen some dynos where you cant even see where vtec kicks in on the graph its blended so well
96accordexproject
Nov 7, 2008 04:55 PM
vteclife
Jan 3, 2008 08:49 AM
2lobes1engine
15
Apr 12, 2004 10:33 AM
civictypenos
Aug 25, 2003 05:29 PM
Flux
Aug 11, 2003 05:22 PM
