climate control lights
Old Feb 13, 2007 | 07:57 PM
dc2-slow's Avatar
Default climate control lights
anyone here can show me how to replace climate control ligths. i have couple lights out. and where can i get those bulbs. i did a research and couldnt find info about it. thanks.
Old Feb 13, 2007 | 08:04 PM
RStoR's Avatar
Default Re: climate control lights (dc2-slow)
Bulbs = dealership
When I replaced mine, I already had my dash apart but pretty sure you have to remove the center console, lower dash console, radio, and then you're able to remove the climate control unit. Not hard but time consuming.
Edit: Here is a link to a '94 Helms manual. Look under Heater - Control Panel 21-25 for details. http://www.redpepperracing.com/technical/main.php
Old Feb 13, 2007 | 08:07 PM
EH-3's Avatar
Default Re: climate control lights (RStoR)
you just need to remove the radio, theres a couple screws there, then there is a screw behind the hazard button and one behind the defrost.
Old Feb 13, 2007 | 09:33 PM
totsie7944's Avatar
Default Re: climate control lights (EH-3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH-3 &raquo;</TD></TR><TR><TD CLASS="quote">you just need to remove the radio, theres a couple screws there, then there is a screw behind the hazard button and one behind the defrost. </TD></TR></TABLE>
yea this is correct, but getting those dam buttons off can be a bitch
Old Feb 13, 2007 | 09:45 PM
dc2-slow's Avatar
alright.. thanks guys. so i can only get the bulbd from dealer. anywhere i can get them cheaper?
Old Feb 13, 2007 | 10:14 PM
EH-3's Avatar
Default Re: (dc2-slow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2-slow &raquo;</TD></TR><TR><TD CLASS="quote">alright.. thanks guys. so i can only get the bulbd from dealer. anywhere i can get them cheaper? </TD></TR></TABLE>
nope. only way to get em cheaper is to get them at a discount, but from what i believe, you can only get those bulbs from the dealer or to buy a used climate control with bulbs in it. correct me if im wrong though. i had to shell out 30 something bucks for all 4 in the climate control and one in the defrost switch.
Old Feb 14, 2007 | 05:36 AM
exies's Avatar
Default Re: (EH-3)
Use this as a guide to remove the climate control.
http://www.team-integra.net/se...D=586
Old Feb 14, 2007 | 05:49 AM
a1320addict's Avatar
Default Re: (exies)
Does anyone know if I put the bulbs in a non-type r climate control panel, will I still get the amber illumination?
Old Feb 14, 2007 | 06:23 AM
EH-3's Avatar
Default Re: (a1320addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if I put the bulbs in a non-type r climate control panel, will I still get the amber illumination?</TD></TR></TABLE>
from what i understand, no you wont. the type r climate control itself has an amber housing if you want to call it, they use the same bulbs as other integra climate controls. they all light up white, they're all the same part number. same goes for the defrost switch and cluster i believe.
Old Feb 14, 2007 | 07:56 AM
white rocket's Avatar
Try here: http://autolumination.com/
Old Feb 14, 2007 | 08:18 AM
EH-3's Avatar
Default Re: (white rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">Try here: http://autolumination.com/</TD></TR></TABLE>
do any of those work for the integra climate controls?
Old Feb 14, 2007 | 08:27 AM
Default Re: (EH-3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH-3 &raquo;</TD></TR><TR><TD CLASS="quote">do any of those work for the integra climate controls?</TD></TR></TABLE>
I'm not sure. I emailed them and they said I should to look at the lights themselves to see if they would work. Most of the threads I've read on these lights have been installed in Civics.
Old Feb 14, 2007 | 08:51 AM
EH-3's Avatar
if they get back to you about that, lmk.
jdmsir4dr
Nov 20, 2008 08:15 AM
Sinner
Jan 23, 2006 07:45 AM
ner0x
Jun 23, 2005 07:17 PM
Carlo
Oct 31, 2003 09:41 PM
PSU
10
Jul 22, 2003 04:07 PM
