92-95 Climate Control Removal
Re: 92-95 Climate Control Removal (DxHatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxHatchback »</TD></TR><TR><TD CLASS="quote">poison said the dash must be removed to remove the climate control
is this true?
can someone help me out, i checked the chilton's and no luck </TD></TR></TABLE>
very false, in fact.
From helms: "remove the center lower panel (where cig lighter is), remove the radio, disconnect the air mix control cable from the heater unit. Remove the tapping screws (3) and pull out the heater control panel. Disconnect the connectors and remove the heater control panel."
FYI, the 3 screws are easy to find. 2 on the bottom front, and one on rear right.
is this true?
Re: 92-95 Climate Control Removal (743)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 »</TD></TR><TR><TD CLASS="quote">
FYI, the 3 screws are easy to find. 2 on the bottom front, and one on rear right.</TD></TR></TABLE>
the only hard thing is going under the dash to take the screws out
Re: 92-95 Climate Control Removal (ridiculous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridiculous »</TD></TR><TR><TD CLASS="quote">yep, very easy. if you have any problems, let me know.</TD></TR></TABLE>
After checking my helms, i decided to try to take mine out, but it wont budge. I took out the screws in the front, and the one in the back, and it wont come out. It's like its still attached to the back somewhere. Any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxHatchback »</TD></TR><TR><TD CLASS="quote">bump how do i remove the faceplate? the two levers are holding it in </TD></TR></TABLE>
use a screw driver and try removing it from the side it will pop out...be careful doing this you might brake/damage the lever...
how do u get the cable back on the climate control? is the a certain tool u use? i can't seem the get mines back on?
Re: 92-95 Climate Control Removal (drvfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drvfast »</TD></TR><TR><TD CLASS="quote">how do u get the cable back on the climate control? is the a certain tool u use? i can't seem the get mines back on?</TD></TR></TABLE> i had hard time putting it back myself but be patient and use a long nose to put it back and twist it to lock...
ner0x
06-23-2005 07:17 PM
Mr Boston
20
10-09-2003 05:33 PM
