Removing EG Climate Control
I've searched, came up with something but the links to the diagrams were all broken. I have to replace some burnt bulbs, I know I have to remove the climate control in order to access the bulbs so if anyone can link to a how to or something similar it'll be greatly appreciated.
Re: Removing EG Climate Control (Carlo)
Remove center console and radio. All the screws needed to remove the climate control are on the underside. After you have the center console spaced cleared up, you will see the 4-5 screws that attach the climate control to the dashboard. Hope this helps, when I removed my climate control, I removed the dash first.
Re: Removing EG Climate Control (Kalokohan)
Thanks for the quick response. While waiting I did some more searching since the search function is very limited.
Found this link in the FAQ section. https://honda-tech.com/zerothread?id=661308
all the screws are pretty easy to get to but you definately need to take out the radio and center console....DONT FORGET THE CABLE UNDER THE GLOVE COMPARtMENT! i totally tried to rip mine oput the first time and thats all that was holding it in. it s like the hot/cold cable? GOOD LUCK!
those clips on the back are hard as hell to get out , (on a 92) and when you put it back on . PUT THE HEAT CABLE ON THE CLIMATE CONTROL FIRST !, then you can clip it on the bottom . haha i may be the only one stupied enough to do it in the wrong order but you never know
Ok, you don't realy have to pull the entire climate control out to replace the bulbs. I unscrewed everything and pulled the climate control out enough so I can get to the clips that are holding the faceplate in.
While I had it off, I dipped the clear oem bulbs into Tamiya Orange Clear paint and let it dry. Reinstalled the bulbs and now my climate control matches my EG6 Cluster, Clock, Defogger switch.
ner0x
06-23-2005 07:17 PM
Petah
04-18-2002 07:11 AM
