Can O2 sensor cause vtec not to switch over?
Old Jan 30, 2007 | 05:09 PM
1clean_ Ej's Avatar
Default Can O2 sensor cause vtec not to switch over?
My buddy has a 92 civic hatchback with a d16z6 and wont's to know if this is the problem we put a new t/b on it and cleaned the vtec solenoid out and still no vtec. and there is only one check engine light and it's the o2 sensor. So what could the problem be? I think the TPS is good on that new t/b not sure tho!
Old Jan 30, 2007 | 05:59 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Can O2 sensor cause vtec not to switch over? (1clean_ Ej)
https://honda-tech.com/zerothread/1880263
https://honda-tech.com/zerothread?id=1812135
Old Jan 30, 2007 | 06:03 PM
bb4socal's Avatar
Default Re: Can O2 sensor cause vtec not to switch over? (HondaPartsHero)
it sure can! your vehicle must be in Closed loop to run Vtec. Here are the three things you need to be in closed loop:
1. O2 Sensor toggling
2. Coolant Temp Sensor
3. Time. Theres a Ecu "clock" and it has to be ready.
mramerica05
Feb 20, 2007 09:34 AM
Tom123456
Jul 28, 2006 12:04 AM
DBallz
Jul 2, 2003 06:00 AM
DRTYHARRYIII
May 26, 2003 07:00 PM
