Engine Code #1 oxygen sensor I think
4th gen 1992 manual accord lx. i hit a deer and getting the same symptoms as https://honda-tech.com/zerothread/1869639 which is bad gas milage plus a lot less power. i jumped the blue service connector and my CEL is just blinking. the light is on for a split second and the a long pause and then on again for a split second. thats #1 which is oxy sensor #1. now is that the one in the front right in front of my 2 rad fans? the one that looks like its going into the exhaust manifold cover? if thats the one i think i need a new one. which ones would you recomend? i know honda uses denso and that they are like $300 to buy from Honda, so does anyone know of a OEM Oxy sensor in the $150 range? thanks in advance.
Read this thread;
https://honda-tech.com/zerothread/1875133
you aren't the only cheap charlie on this website LOL
ok now my next question is how do you take it off? like without cutting the wires, bc i think i have a good o2 sensor in another accord but i cant seem to get the manifold cover off. has anyone else done this before that could explain it 2 me bc iv never have.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude »</TD></TR><TR><TD CLASS="quote">Read this thread;
you aren't the only cheap charlie on this website LOL</TD></TR></TABLE>
lmao dam that is funny.
unplug the sensor connection, squirt the base of the sensor with PB Blaster penetrating fluid, also squirt the 3-12mm bolts on the shroud. Then remove the shroud; you have to 'fanagle' it up and out. Then use your oxygen sensor socket and take out the sensor. I usually use an impact to bump the sensor loose the first 1/6 of a turn.
haha thanks, i know im cheap but you would understand if u saw my car. i got it for free and my goal is to get to 300k. im at 197k and was running strong untill this o2 sensor. Thanks for the help.
Well, i changed the o2 sensor and my cars power is back, so everything is back to normal. as to gas milage ill see this week to see how i do. Thanks a lot for your help guys.
Dennin01
Acura TL, RL & ZDX
Sep 23, 2018 07:17 AM
