Engine Code #1 oxygen sensor I think
Old Jan 28, 2007 | 03:36 PM
JohnD1079's Avatar
Default Engine Code #1 oxygen sensor I think
4th gen 1992 manual accord lx. i hit a deer and getting the same symptoms as https://honda-tech.com/zerothread/1869639 which is bad gas milage plus a lot less power. i jumped the blue service connector and my CEL is just blinking. the light is on for a split second and the a long pause and then on again for a split second. thats #1 which is oxy sensor #1. now is that the one in the front right in front of my 2 rad fans? the one that looks like its going into the exhaust manifold cover? if thats the one i think i need a new one. which ones would you recomend? i know honda uses denso and that they are like $300 to buy from Honda, so does anyone know of a OEM Oxy sensor in the $150 range? thanks in advance.
Old Jan 28, 2007 | 03:41 PM
JDM_DC4_Fanatic's Avatar
Default Re: Engine Code #1 oxygen sensor I think (JohnD1079)
your car is obd1, there is only 1 O2 sensor
Old Jan 28, 2007 | 04:44 PM
hondadude's Avatar
Read this thread;
https://honda-tech.com/zerothread/1875133
you aren't the only cheap charlie on this website LOL
Old Jan 28, 2007 | 07:58 PM
JohnD1079's Avatar
ok now my next question is how do you take it off? like without cutting the wires, bc i think i have a good o2 sensor in another accord but i cant seem to get the manifold cover off. has anyone else done this before that could explain it 2 me bc iv never have.
Old Jan 29, 2007 | 01:54 AM
K24xCM5's Avatar
Default Re: Engine Code #1 oxygen sensor I think (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Read this thread;
you aren't the only cheap charlie on this website LOL</TD></TR></TABLE>
lmao dam that is funny.
Old Jan 29, 2007 | 08:12 AM
hondadude's Avatar
unplug the sensor connection, squirt the base of the sensor with PB Blaster penetrating fluid, also squirt the 3-12mm bolts on the shroud. Then remove the shroud; you have to 'fanagle' it up and out. Then use your oxygen sensor socket and take out the sensor. I usually use an impact to bump the sensor loose the first 1/6 of a turn.
Old Jan 29, 2007 | 08:01 PM
JohnD1079's Avatar
haha thanks, i know im cheap but you would understand if u saw my car. i got it for free and my goal is to get to 300k. im at 197k and was running strong untill this o2 sensor. Thanks for the help.
Old Feb 1, 2007 | 07:44 PM
JohnD1079's Avatar
Well, i changed the o2 sensor and my cars power is back, so everything is back to normal. as to gas milage ill see this week to see how i do. Thanks a lot for your help guys.
Dennin01
Acura TL, RL & ZDX
Sep 23, 2018 07:17 AM
cholder919
Oct 19, 2011 12:41 AM
boltnut
Jan 7, 2006 08:43 PM
BAZ
Apr 28, 2004 08:55 AM
sagaprelude
Feb 25, 2002 12:59 PM
