Trouble Code P0141-Oxygen Sensor
Old Jan 7, 2006 | 07:29 PM
boltnut's Avatar
Default Trouble Code P0141-Oxygen Sensor
Check engine light is on, code is P0141. Told by autozone that it is a heated oxygen sensor....but which one??
Please helt. Also, NKG or Bosch????
Thanks so much.
Old Jan 7, 2006 | 08:32 PM
Ross 2.0's Avatar
In a Junkyard near you.
I would be happy to help if you told us what year and how many cylinders. If you want the sensor go to your dealer to get the part, it may cost more but aftermarket parts have a bad reputation for not working with a Honda. But if I took a guess I would think it's an NGK sensor. What you can do is bring your sensor in the parts store with you and see if it matches the new part. If you need to modify the wire harness it's not the right one. BUT that's only if this is the right code description. It may be something totally different depending on what kind of accord you have.
Old Jan 7, 2006 | 08:43 PM
BLKFLSH's Avatar
Default Re: Trouble Code P0141-Oxygen Sensor (boltnut)
I'm pretty sure the heated oxygen sensor will have more wires than the other one. Three instead of two. Check it out. My guess is the heated sensor is the one after the catalytic converter. And like moogoo said, NGK is probably oem sensor. I know it's not bosch
leonardsmith
Honda CR-V & Element
Dec 1, 2021 06:33 PM
Dennin01
Acura TL, RL & ZDX
Sep 23, 2018 07:17 AM
dave2299
Honda Civic (2001 - 2005)
Oct 17, 2012 03:30 PM
maat4449
Jan 10, 2011 10:58 AM
HATCHFREEK
Mar 19, 2003 10:32 AM
