Need help. If I can move the pistons while they r in the block, is it bad?
Old May 16, 2002 | 07:11 PM
TurboR's Avatar
New User
Default Need help. If I can move the pistons while they r in the block, is it bad?
I was checking my block out and noticed that I can move the pistons to side to side by pushing on them. Is it bad? Is there too much clearence?
Old May 16, 2002 | 07:14 PM
Liltrix's Avatar
Default Re: Need help. If I can move the pistons while they r in the block, is it bad? (TurboR)
I think so! Is that when the crank is TDC?
Old May 16, 2002 | 07:17 PM
TurboR's Avatar
New User
Default Re: Need help. If I can move the pistons while they r in the block, is it bad? (Liltrix)
tdc?
Old May 16, 2002 | 07:31 PM
earl's Avatar
No, that doesn't mean the block is bad. You are actually rocking the top of the piston which has a much smaller diameter than the skirt of the piston. If they didn't rock, you might be having ring-land problems from over heating the pistons. Depending on the type of piston, you should be able to slide a feeler guage of from .010-.015 into the gap.
Old May 16, 2002 | 07:36 PM
2K_TEG's Avatar
Default Re: Need help. If I can move the pistons while they r in the block, is it bad? (earl)
EDITED: misinformation.
[Modified by 2K_TEG, 12:34 AM 5/17/2002]
Old May 16, 2002 | 08:06 PM
earl's Avatar
Default Re: Need help. If I can move the pistons while they r in the block, is it bad? (2K_TEG)
WAIT, WAIT...That's at the skirt, not the top of the piston. It's much looser on top. You can't measure skirt clearance with the pistons and rings installed (unless thru the pan).
Earl
Old May 16, 2002 | 08:34 PM
2K_TEG's Avatar
Earl
I should have looked at the pictures too. Thanks for clarifing.
Old May 17, 2002 | 04:59 AM
Dublocivic's Avatar
On my buddies turbo b18c (w/Ross pistons with the correct ring gap) rocked a little.. No biggie.
Ryhaz
10
Jan 14, 2014 07:57 AM
kyden
Jun 12, 2009 08:16 AM
Robban26
15
Jan 24, 2004 01:31 AM
5thgencivic
Nov 29, 2003 03:26 PM
