oil blow by coming from breather filter
Old May 16, 2002 | 02:39 PM
uneekcrx's Avatar
Default oil blow by coming from breather filter
i have a k & n breather filter on my motor...but there's a little oil coming from it and it looks pretty dirty...so can i clean it or what are you guys doing to remedy this blow by from the valve cover situation? i'm also trying to avoid getting a catch can...i thought i read on this board that people were running a piece of hose directly under the car are something....maybe not
Old May 16, 2002 | 05:43 PM
Ri5e's Avatar
Default Re: oil blow by coming from breather filter (uneekcrx)
I have a hose connected to my valve cover breather, running down under my car
Old May 16, 2002 | 08:00 PM
Cramerox's Avatar
why avoid a catch can? Just wondering.
Old May 16, 2002 | 09:03 PM
uneekcrx's Avatar
Default Re: oil blow by coming from breather filter (BG Boost)
it's just a piece of hose connected directly from the top of the valve cover(where a breather filter would go) straight down to the underneath of the car? now my question is...is this harming anything? of is it ok?
Old May 17, 2002 | 01:06 AM
intekragsr's Avatar
im curious too, ttt
Old May 17, 2002 | 07:26 AM
boostedhb's Avatar
Depends on how much blow by you are getting. I was getting a huge amount of blow by and oil coming from my breather. But I had a bent rod and melted piston . But if you are only getting a bit of blow by you should be fine with just running a small tube from the breather down to the ground.
Old May 17, 2002 | 09:12 AM
TurboSohc's Avatar
Yeah you shouldnt see any problems with runing a tube to the bottom of the car.
Old May 17, 2002 | 10:07 AM
abraunb16's Avatar
New User
Default Re: oil blow by coming from breather filter (TurboSohc)
I'm sure the EPA wouldn't like the tube coming off the vavle cover. I know when I used to run my car like that I would get the occasional burnt oil smell, besides that I had no problems with it.
Old May 17, 2002 | 10:09 PM
inspyral's Avatar
Default Re: oil blow by coming from breather filter (abraunb16)
Catch can
Old May 17, 2002 | 10:35 PM
FBP Ex-T's Avatar
Default Re: oil blow by coming from breather filter (inspyral)
in a catch can, the oil just stays in there or is it routed to another place??
Old May 17, 2002 | 10:43 PM
SiRkid's Avatar
Default Re: oil blow by coming from breather filter (FBP Ex-T)
stays i beleive....then just pour it back into the motor periodically????
Old May 18, 2002 | 12:38 AM
inspyral's Avatar
Default Re: oil blow by coming from breather filter (SiRkid)
Oil stays in the can.
I wouldn't pour that oil back into the engine, just toss it.
Old May 18, 2002 | 03:40 AM
maxim's Avatar
LOL, I would not put that oil back in the engine, especially if the catch can has any dirt or metal particles in there.
Old May 18, 2002 | 06:43 AM
csufweed's Avatar
Default Re: oil blow by coming from breather filter (maxim)
if you run a tube to the ground, you're not allowed on any tracks...
Old May 18, 2002 | 07:53 AM
SiRkid's Avatar
i was just sayin.i knwo it stays in there..didnt know if ya pour it back in or not..i dont have one..so
darkcivic90
16
Dec 18, 2011 11:53 PM
bowtieboy911
May 16, 2011 07:45 AM
Vencill66
Feb 24, 2008 04:53 PM
D21X
Oct 12, 2003 08:37 PM
bigstatik
Jul 18, 2003 02:04 PM
