I keep blowing my Instrument panel/Taillight/stop light FUSE "10"
Old Jan 13, 2007 | 08:59 PM
-HONDA-'s Avatar
Default I keep blowing my Instrument panel/Taillight/stop light FUSE "10"
okay you guys i keep poping my fuse that controls the lights for my cluster and my taillights/stop lights! i dont know whats going on! someone please help me on where i should start on fixing this problem? any relays? Please LMK ASAP this is my DD thank you for reading any links too similiar problems will be very helpfull.
car is a 1994 honda civic CX
b16a2 motor(OBD1)
alarm(doesnt work right now dont know whats wrong with it?)
cd player
integra DC cluster/Dash Swap
PLEASE LMK
Old Jan 13, 2007 | 09:10 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: I keep blowing my Instrument panel/Taillight/stop light FUSE "10" (-HONDA-)
this the car with the cluster swap?? if so has it worked fine before the swap?
Syndacate's Avatar
I can tell you that it's probably a short someplace...where I don't know.
Old Jan 13, 2007 | 09:51 PM
Tjames8864's Avatar
Default Re: I keep blowing my Instrument panel/Taillight/stop light FUSE "10" (Syndacate)
probably a short...i remember i had a problem with the wiring in my drivers side headlight wiring, it would always go out and blow bulbs and sure enough every time my cluster would go too. I fixed the wiring to the headlight and havent had a problem since
Old Jan 13, 2007 | 10:17 PM
kv_sir's Avatar
Default Re: I keep blowing my Instrument panel/Taillight/stop light FUSE "10" (Tjames8864)
I would go with the rest of the guys saying it's a short somewhere. check behind your fuse box and follow the wire that goes to fuse 10 and take a look. Does the fuse blow at random, or have you noticed a certain pattern/process in how/when it blows.
Old Jan 14, 2007 | 08:06 AM
-HONDA-'s Avatar
the fuse blows as soon as i put/plug the new fuse in and turn the key?....
Old Jan 14, 2007 | 08:08 AM
Tjames8864's Avatar
Default Re: (-HONDA-)
like i said its a short somewhere check your wiring
Old Jan 14, 2007 | 08:12 AM
-HONDA-'s Avatar
k im gonna go check out my radio/cd player harness! i know there's a couple of wires that are pre cut and i didnt have too use.!
Old Jan 14, 2007 | 08:22 AM
3.point.2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -HONDA- &raquo;</TD></TR><TR><TD CLASS="quote">k im gonna go check out my radio/cd player harness! i know there's a couple of wires that are pre cut and i didnt have too use.!</TD></TR></TABLE>
i was blowing the same fuse for a while once and it turned out to be because there was a wire from the radio harness that was shorting the circuit.
Old Jan 14, 2007 | 08:49 AM
-HONDA-'s Avatar
ill go check right now!
Old Jan 14, 2007 | 09:24 AM
-HONDA-'s Avatar
Okay my fuse isnt blowing anymore and the cluater lights are working but now my Taillights arent working? what should i look at now?
Old Jan 14, 2007 | 09:47 AM
-HONDA-'s Avatar
taillights Dont work you guys! but cluster lights work? i thought this fuse was hookep up to them all/? LMK ASAP
lilsicsoul
Mar 14, 2009 02:30 PM
-HONDA-
Jan 15, 2007 03:23 PM
silverboost
Jan 2, 2007 01:52 PM
TenLarge
10
Jun 17, 2005 10:23 PM
Streetdreams022
Jan 8, 2005 08:20 AM
