fuses
wutup ppl...ok so heres the problem...i keep blowing the tail light/cluster fuse (the cluster works its just that it doesnt light up..i've changed it twice already and it keeps blowing...last night i also blew the fuse that make the RPM and MPH work...can any1 tell me which fuse i have to change for that?? or the cause of why my fuses are blowing??? thanks and any help is aprreciated...
make sure you don't have any wires grounding out in your tail light harness, or coming off your deck even. i had a remote wire i wasn't using ground out and blow all sorts of fuses multiple times until i figured out what it was.
thanks...do u know the fuse that makes your cluster function (RPM, MPH, FUEL) the cluster lights up it just doesnt function, also my clock doesnt work and my reverse lights dont work...anyone kno wut fuse or fuses this can be?!???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Streetdreams022 »</TD></TR><TR><TD CLASS="quote">do u know the fuse that makes your cluster function (RPM, MPH, FUEL)</TD></TR></TABLE>
would that fuse be in the fusebox under the dash or the fuse box under the hood??? my hood fuse box has no diagram so its hard to see which one is which
it was the wires for the tailight....i put mad electrical tape on it and hasnt blown yet...also the fuse for the cluster (mph, rpm) wasnt even there...lol so i just put a new fuse and it worked....thanks again
lokoo23
20
Sep 12, 2009 08:15 AM
lilsicsoul
Mar 14, 2009 02:30 PM
timntam
Feb 3, 2006 11:10 AM
SiR HatchAlot
Mar 28, 2004 09:31 AM
