D series block sleeves?
I'm lookin to put some serious boost to my d16z6. How much do the sleeves cost, where can i get them, and are they complicated to install? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wann495909 »</TD></TR><TR><TD CLASS="quote">I'm lookin to put some serious boost to my d16z6. How much do the sleeves cost, where can i get them, and are they complicated to install? Thanks</TD></TR></TABLE>
a machine shop has to do it..
i just paid $925 to slevee bore and hone my bseries.. and that was $150 off the normal price
From: Off the Florida Keys, in a place called Kokomo, USA
no point sleeving a d unless you overbored or whatever. if your still at fact. bore or .10 over or something, you dont need to sleeve for boost. like 400whp+ has been proven on stock sleeves, just maybe a block guard or something
so i really dont need sleeves? stock ones will take like 20psi? if thats the case then hell yeah. thanks for the info
ya, if you have a stock block, you can do light honing, or a .10 bore and not need sleeves. i've seen d16z6's go with 30psi on stock sleeves. but i think ppl are using block guards, but not completely sure myself if block guards are good or bad
while the D blocks are def. strong i wouldn't suggest a daily 20psi
Yeah you can do it but the question is for how long..
Just hone your stock block, and slowly build up the boost and figure out what you want out of your engine setup.
So all in all.. IMO don't sleeve it don't bother with a cheap block guard either they can restrict coolant flow and create hot-spots (look into golden eagle or custom guards if you're set on running them).
Yeah you can do it but the question is for how long..Just hone your stock block, and slowly build up the boost and figure out what you want out of your engine setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift_n_shift »</TD></TR><TR><TD CLASS="quote">no point sleeving a d unless you overbored or whatever. if your still at fact. bore or .10 over or something, you dont need to sleeve for boost. like 400whp+ has been proven on stock sleeves, just maybe a block guard or something</TD></TR></TABLE>
good info above!
the thing i would be more worried about with boost is the rods! LS is an option!
and do not forget ARP studs
good info above!
b18sihatch
Jul 13, 2006 06:33 PM
spoonhatchblack
Dec 5, 2005 10:36 PM
