full throttle problems
Old May 13, 2002 | 06:13 PM
G unitvdvdv's Avatar
Default full throttle problems
Im running a jackson with 8psi and the head is completely reworked and everything else on the motor is brand new except the pistons and rods. I have one problem, when i am on it full throttle at lets say 4 grand or so, before it his VTEC the car feels hesistant, and it burps some and shurgs faintly, but then goes ballistic with acceleration when vtec engages. Could it just be an old clogged cat battling with backpressure. 90k on it. Hit me back with an answer thanks.
Old May 13, 2002 | 07:54 PM
Default Re: full throttle problems (Jackson4Door)
nobody has any idea???
Old May 13, 2002 | 11:21 PM
fork's Avatar
you say every thing is new did you replace the tps, and did you use the right one. Check for vacume leaks and try retarding the timing a little because if your getting a detonation signal from the knock sensor the computer will kill the motors power
Old May 15, 2002 | 09:12 AM
Doctor CorteZ's Avatar
Default Re: full throttle problems (fork)
hes running ten degrees on the timing light , try again
Old May 15, 2002 | 09:37 AM
88_SC_CRX_Si's Avatar
New User
Do you have a A/F gauge (every little bit of info helps....) hehehe. Also, what fp are you running? What does your plugs look like. Are you using the JR FMU? Have you checked your cam alignment.
I get the impression it's leaning out on you on tip in...
[Modified by 88_SC_CRX_Si, 10:45 AM 5/15/2002]
HseriesWeaksauce
Mar 8, 2011 06:23 AM
mrmoomoox
May 10, 2010 07:42 AM
JENNY_EG6
Aug 14, 2009 04:17 AM
zensoku207
Mar 21, 2005 10:49 PM
Antilag
Aug 27, 2004 06:26 AM
