no speedo after swap replaced vss!
Old Dec 29, 2006 | 11:06 AM
b18bcrxhf's Avatar
Default no speedo after swap replaced vss!
i swapped a y8 into a 96 hx and my speedo wont work so i bought a new vss and put a new plug on so i know its got connection and still no luck... it used to bounce around alittle before but still worked most of the time. The motor i bought sat up for a while could the alternator be causing the issue.. the battery isnt charging very well but i know the alternator isnt completely dead. Ichecked the fuses too. LMK what yall think please
Old Dec 29, 2006 | 01:40 PM
sleeper101's Avatar
Default Re: no speedo after swap replaced vss! (b18bcrxhf)
Did you get Check-Engine-Light blinking ?
if so, find out what code(s) u have.
Old Dec 29, 2006 | 01:45 PM
Jimmy's Avatar
Global Moderator
Code 17 VSS - speed sensor
Check inside the plug That plug's into the speed sensor and make sure they didn't break off inside the plug.
Did you swap the vss's out with a known working one?
Also there's a good chance your alternator is about to take a BIG **** on you.
Old Dec 29, 2006 | 02:04 PM
b18bcrxhf's Avatar
Default Re: no speedo after swap replaced vss! (sleeper101)
well i had no bulb in my check engine light so whoever had the car b4 me took it out... so for the past hour ive been taking my cluster apart and replacing the bulb and check all the connections and everything looks good. I put it back together fired the car up and no check engine light. what would be a good sensor to unplug to see if my check engine light will come on? that way i can make sure that isnt fuggin up too
Old Dec 29, 2006 | 02:07 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bcrxhf &raquo;</TD></TR><TR><TD CLASS="quote">well i had no bulb in my check engine light so whoever had the car b4 me took it out... so for the past hour ive been taking my cluster apart and replacing the bulb and check all the connections and everything looks good. I put it back together fired the car up and no check engine light. what would be a good sensor to unplug to see if my check engine light will come on? that way i can make sure that isnt fuggin up too</TD></TR></TABLE>
Do you know how to jump codes off?
Unplug the map, or O2 sensor.. unplug which ever you want.
Old Dec 29, 2006 | 02:38 PM
b18bcrxhf's Avatar
wow i unplugged o2 and no check engine light then i plugged o2 back and i unplugged map sensor and started the car car both times and unplugged the battery too. what could be causeing the check engine light not to work?
Old Dec 29, 2006 | 09:11 PM
b18bcrxhf's Avatar
bump i have mo check engine light anyone know what i should check?
wattynz
Mar 24, 2012 10:24 PM
DDDAAN Si
Jun 1, 2011 05:52 PM
smokinloc
12
Feb 16, 2010 11:17 AM
civic_66
12
Sep 14, 2008 12:24 PM
jdmjay04
Mar 29, 2004 11:13 AM
