Using a coolant/oil cooled turbo only with oil???
Old Dec 21, 2006 | 09:50 AM
SnIpErS-GsR's Avatar
Default Using a coolant/oil cooled turbo only with oil???
Tried searching but found nothing on this. The turbo I have is a t25/t28. If anyone has done it before or has any info on it that would be great. I have heard about people upgrading from a coolant/oil cooled turbo to just oil, but the turbo only had bungs for oil. As mine has four bungs for what I'm assuming is two coolant and two oil. Thanks in advance as always guys.
Old Dec 21, 2006 | 10:05 AM
slow poke's Avatar
Default Re: Using a coolant/oil cooled turbo only with oil??? (SnIpErS-GsR)
Yes, you can run them with only oil but if you add the water lines the turbo will last longer! If you just don't have the flow now and wanna get it running, just the oil lines will work fine.
Old Dec 21, 2006 | 10:06 AM
DS002's Avatar
Banned
Im running mine without coolant , i just blocked off the ports . But it is now smoking , im not sure if the oils getting too hot and smoking because im not running coolant . But im also only running 5W-20 so ill probably switch to something thicker , so that might also be the problem . Hopefully someone will chime in that has an exact answer for you though .
Old Dec 21, 2006 | 11:06 AM
EK k kay's Avatar
Default Re: Using a coolant/oil cooled turbo only with oil??? (DS002)
If you have water ports, what's the reason to not use them? I sure as hell would if I had them on my turbo.
Old Dec 21, 2006 | 02:59 PM
eg:R's Avatar
Default Re: Using a coolant/oil cooled turbo only with oil??? (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">If you have water ports, what's the reason to not use them? I sure as hell would if I had them on my turbo.</TD></TR></TABLE>
Old Dec 21, 2006 | 08:15 PM
The only real reason I was asking was to make sure I didn't "have" to. I really dont feel like splicing into coolant lines. But if it will make the turbo last longer I would do it. Thanks for all the great advice!
Old Dec 21, 2006 | 08:17 PM
wantboost's Avatar
Who is Mr Robot?
and if it's a gt series ball bearing turbo YOU HAVE TO RUN THEM
Old Dec 21, 2006 | 08:44 PM
Default Re: Using a coolant/oil cooled turbo only with oil??? (wantboost)
Any tell tell signs???
Old Dec 21, 2006 | 08:50 PM
Tchleung's Avatar
Why is it so hard for ppl to run coolant to the turbo if it has ports for them? Damn it's like 4 feet of hoses, and a few fittings... wth. It's like some ppl can install a turbokit, but are afraid to run water lines. The small amount that the water will heat up from going through the turbo FAR outweighs throwing the turbo life out the window.
Old Dec 21, 2006 | 08:52 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnIpErS-GsR &raquo;</TD></TR><TR><TD CLASS="quote">Any tell tell signs???</TD></TR></TABLE>
huh
Old Dec 21, 2006 | 09:16 PM
Never mind, I will prob end up running some coolant lines also. Thanks for all the advise...
HondaHatch1
Jul 31, 2010 09:21 AM
welfarepc
Jan 10, 2007 10:26 AM
sycamore
Oct 23, 2005 12:00 PM
nota-eg
Aug 15, 2005 07:17 AM
mojord
Apr 26, 2002 10:20 AM
