300+hp with a 15g?
Old Dec 15, 2006 | 06:25 AM
elcangripapi's Avatar
Default 300+hp with a 15g?
Ok, well I did a search and only found one page that didnt even answer the guys question.
I do infact remember kelly saying that he made 300+ on a 19t.
But are the 15g and the 19t the same size turbo and only two differnt packeges.
But my question is is it possible to get 300+ on a 15g kit? Thats my goal.
my setup:
Vitaras
eagle rods
dsm 450s
greddy kit
intercooler
walbro 190
Modified by elcangripapi at 7:36 AM 12/15/2006
Old Dec 15, 2006 | 06:56 AM
TheShodan's Avatar
Moderator
Default Re: 300+hp with a 15g? (elcangripapi)
No. To get even about 270whp on the D series motor, the turbo needs to be efficient at over .28kg/sec even at 7500rpms at over 15 psi of boost. this turbo is capable of less than 35lbs/min on the compressor wheel. It really wouldn't be possible effectively to get 300whp out of this. Here's the map for you as a reference.
Old Dec 15, 2006 | 09:34 AM
jaggrieger30's Avatar
There is no way that you will get 300hp out of the 15g. The max that i have seen is around 260hp @ 16lbs. It makes it even harder that you have low compression with the vitaras.
Old Dec 17, 2006 | 05:23 PM
So does anybody know if the 15g is the same as a 19t?
Old Dec 17, 2006 | 05:34 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (elcangripapi)
they arent the same...
a 15g is a 15g.. a 19t is a 19t
different number = different turbo
Old Dec 17, 2006 | 06:02 PM
Im only asking because in another thread the question of how much psi/hp a 15g can make was asked. And kelly replied that he made 300+ on a 19t. Now why would he say that if there wasnt a similarity?...
Old Dec 17, 2006 | 06:04 PM
wantboost's Avatar
Who is Mr Robot?
they are NOT the same
19t is bigger and more efficient
Old Dec 20, 2006 | 08:17 AM
So does anybody else have any helpful input? Possibly a flow graph for a 19t? I understand that the 15g may not reach 300hp. But I still want to know the diff between the two turbos.
Wantboosts posts were o-so insightful...
Old Dec 20, 2006 | 08:51 AM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elcangripapi &raquo;</TD></TR><TR><TD CLASS="quote">So does anybody else have any helpful input? Possibly a flow graph for a 19t? I understand that the 15g may not reach 300hp. But I still want to know the diff between the two turbos.
Wantboosts posts were o-so insightful...</TD></TR></TABLE>
I promise you that you can find the graphs with the google search engine just as fast as we could.
And I think with vitaras and such low compression, you need a turbo that is efficient at a higher boost levels, which would honestly put a 19T at its max as well.
Old Dec 20, 2006 | 04:26 PM
92gsrteg's Avatar
i got a good idea for u to make ur 300whp, swap in the 18g turbo for the 15g, my freind did it on his d series, everything fits the same and just use the 18g downpipe, u will make good power then and the turbo is actually a really good size for a build d series, u can pick one up cheap and use some money from sellin ur 15g, ur practically gettin the 18g for free, u'll be good, goodluck
Old Dec 20, 2006 | 05:40 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: 300+hp with a 15g? (92gsrteg)
i forgot but i was at abotu 250whp with a 15G on my Z6 with Vitaras...
Old Dec 20, 2006 | 06:09 PM
What psi were you at to make 250?
Old Dec 20, 2006 | 06:13 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
i was running 16psi....
Old Dec 20, 2006 | 08:49 PM
TheShodan's Avatar
Moderator
kg/sec and multiply by 132.177 for lbs/min
Old Dec 20, 2006 | 08:57 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (TheShodan)
34.36 lbs/min and thats tapped out. keep in mind that would be 340crank hp at max.. it would get you closer to 300 but not all the way there. and thats assuming 100% ve out of the motor
Old Dec 20, 2006 | 11:04 PM
quicksilver1689's Avatar
i ♥ snails
YEah 100% VE, real world 270-280whp max
usafdad120108
Jun 29, 2011 07:29 PM
Baron55
Dec 9, 2005 04:54 AM
BiG DaDDy O
May 10, 2004 06:10 PM
Buzzbomb
Jun 4, 2003 08:57 PM
BlackB18C
Jan 25, 2002 04:48 AM
