Built B16A, ITR oil pump, CONSTANT 60+ psi of pressure. Turbo inlet pressure?
Old Dec 9, 2006 | 05:51 PM
Frozen E's Avatar
H-T White Ops
Default Built B16A, ITR oil pump, CONSTANT 60+ psi of pressure. Turbo inlet pressure?
Hey guys,
Just wondering here. Back when my B16 was stock I would see about 12-16 psi idle and 35 psi at around 3K RPM. Everybody told me that was normal. Great.
Now, that engine blew itself to pieces. When I got the rebuild done, Scott from importbuilders installed a new ITR oil pump. More oil flow, better for the engine, right? Anyway, when driving around town the oil pressure stays a hell of a lot higher than it used to.
And on the highway at about 3K RPM the oil pressure always seems to hover around the 60-65 psi mark. It doesn't even come close to where it used to be at with the stock engine.
Warmed up and at idle it would sit at about 20-24.
I'm using the fast turbo oil line kit on a T3/T04 .48 trim turbo. I believe it comes with a -3AN supply line if I remember correctly. I'm thinking about installing an oil pressure gauge at the turbo's inlet just to make sure I don't blow the seals AGAIN.
So anyway, two part question.
Are the pressures I'm seeing about right for a B16 block/ITR pump setup?
And what kind of pressure should I be seeing at the turbo oil supply inlet with a -3AN line to keep things safe in there?
Old Dec 9, 2006 | 08:19 PM
HiProfile's Avatar
Default Re: Built B16A, ITR oil pump, CONSTANT 60+ psi of pressure. Turbo inlet pressure? (IslandSi)
I don't know if the b16 & gsr/itr pumps are different internally, I do know the only diff between GSR and ITR is the lack of a washer under the bypass bolt. This would lead to higher bypass (max) pressure, not higher pressure at lower RPM's.
Regardless, I always suggest a .060" restrictor before the turbo.
Old Dec 9, 2006 | 08:25 PM
abnaasefmb's Avatar
Default Re: Built B16A, ITR oil pump, CONSTANT 60+ psi of pressure. Turbo inlet pressure? (HiProfile)
i see oil pressure a little higher than that with my old stock b16.
Old Dec 9, 2006 | 10:22 PM
F20Cteg's Avatar
35psi at 3K, very bad. Honda spec is at least 50psi at that rpm. Minimum 10psi at idle.
Also, a 0.045" restrictor would be better.
Old Dec 9, 2006 | 10:47 PM
Frozen E's Avatar
H-T White Ops
Default Re: Built B16A, ITR oil pump, CONSTANT 60+ psi of pressure. Turbo inlet pressure? (F20Cteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg &raquo;</TD></TR><TR><TD CLASS="quote">
I don't really remember what the exact numbers were. All I know is that I asked this question back when I first put the turbo in and everybody was in agreement that whatever I was reading was right for a stock B16.
Thanks for those restrictor sizes. I guess I'll google a place to find them. Unless some of you guys can post up some links for me.
Old Dec 9, 2006 | 11:33 PM
siblues's Avatar
Here is a link to the restrictor size mentioned above but it seems a little expensive at 14 bucks?
http://www.atpturbo.com/Mercha...e=OIL
Old Dec 10, 2006 | 07:16 AM
Frozen E's Avatar
H-T White Ops
Default Re: Built B16A, ITR oil pump, CONSTANT 60+ psi of pressure. Turbo inlet pressure? (siblues)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote">Here is a link to the restrictor size mentioned above but it seems a little expensive at 14 bucks?
http://www.atpturbo.com/Mercha...e=OIL</TD></TR></TABLE>
Thanks man. I'm probably going to order one from them along with some silicone drain hose. $14 is a hell of a lot cheaper than a turbo rebuild.
Old Dec 10, 2006 | 08:50 AM
HiProfile's Avatar
A brand new b16a2 pump is supposed to read 50psi at 3k - at 176F. 200F for oil in a b16-T isn't uncommon if you've been running a while (and boosted any bit), and track cars are known to get past 240F. It would probably read a bit higher right after the needle hit opperating temp (fan on twice, still parked). This is also assuming its fresh 5w or 10w-30.
All I did for my restrictor was take the first fitting between the line and distribution block (NPT to AN), heat it with a torch for a while, then stick a bunch of solder & flux in there. After it solidified, I drilled a .060" hole in it. THe solder is good to ~500F, so no worries about it being dissolved.
Old Dec 10, 2006 | 06:19 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">All I did for my restrictor was take the first fitting between the line and distribution block (NPT to AN), heat it with a torch for a while, then stick a bunch of solder & flux in there. After it solidified, I drilled a .060" hole in it. THe solder is good to ~500F, so no worries about it being dissolved.</TD></TR></TABLE>
What kind of solder did you use? The fitting you filled was brass, right? So I'm assuming you didn't just use regular old 50/50 or 95/5 soft solder on a roll. Must have been the brazing sticks.
Either way, that's a hell of an idea, and a good way to save a few bucks. Hell, I might just do it at work tomorrow.
Thanks for the DIY tip.
Old Dec 11, 2006 | 07:26 PM
abnaasefmb's Avatar
Lol, Hi is the ultimate DIYer, he would make his own pistons if he could! lol
EF guys are very resourceful
Old Dec 11, 2006 | 08:23 PM
Frozen E's Avatar
H-T White Ops
Damnit, forgot to take the fitting to work today. Not like I would have had much chance to get it done anyway. Was busy fixing an AC leak over at the gym all day. Concrete ceilings suck. Especially when I feel like I'm walking around on broken ankles. Damn you Honolulu marathon.
Old Dec 12, 2006 | 06:20 AM
mike1114's Avatar
Default Re: (IslandSi)
My recent build, I see 45psi at idle after warmup. Cold start is like 80-100psi.
At 3000rpms, I see over 65psi.
I run 20W-50 oil but its usually hot as hell here in Fla. In wintertime, I run lighter oil.
Oil temps sometimes see 230F on a 95F+ day, daily driving in stop and go traffic. Usually more around 200-210F though normally.
cobra2326
Mar 8, 2006 07:28 AM
smokey2.0
Apr 20, 2004 01:33 PM
Snafu-Si
Apr 2, 2003 11:00 AM
Speed PHreak
Apr 10, 2002 04:32 PM
