grinding third please please help
so i have a 94 gsr and when the car is warm after driving it a bit it grinds every time in 3rd also when its high reved i have to get out of 2nd and wait till the rpm hits around 3 so it will go in smooth does anyone noe wut could be my problem thanx
simply your trans is fked.. you need to replace the gear.. beating on your honda has a tendency to cause 3rd to mess up first.. its kinda common actually
i had a bad 3rd and 4th grind and then when i had a new clutch put in, the shop owner changed the tranny oil and its only grided once since, tranny's a 92 cable ls with a turbo jdm gsr. runs good now. try changin the oil with somethin good.
you noe i did just drained my tranny oil and added new oil and it still does it so does this mean my gear is just fucked up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtny »</TD></TR><TR><TD CLASS="quote">Change your tranny fluid with GM synchromesh. I had some grinding in my EM1 but and it eliminated it. </TD></TR></TABLE>
It wasn't eliminated. It was covered. Changing fluids are band aid repairs at best. You will have to check to see if your synchro, sleeve, or gear have been damaged.
I can not comment on cost as I do my own work. The parts are not expensive.
m-
m-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 87shytwhip »</TD></TR><TR><TD CLASS="quote">simply your trans is fked.. you need to replace the gear.. beating on your honda has a tendency to cause 3rd to mess up first.. its kinda common actually</TD></TR></TABLE>
Don't be a moron. The gears are fine.
The synchro for 3rd gear is worn out and is not able to do it's job.
You should have the trans rebuilt so that you don't mess up the dog teeth on the gears.
Contact gear-speed, they do good work.
Luchini
Dec 4, 2006 10:04 PM
