best oil grade for a honda engine with a slightly smoking turbo.
Old Dec 7, 2006 | 04:12 PM
RACEPAK's Avatar
Default best oil grade for a honda engine with a slightly smoking turbo.
i want to replace my oil tommorow.
i have a slightly smoking turbo and a stock engine.
what grade of oil would you reccomand?
thanks
Modified by RACEPAK at 6:12 PM 12/7/2006
Old Dec 7, 2006 | 04:14 PM
CRXDrew's Avatar
Got an oil restrictor on it already?
You can use 10w40 but thats only a bandaid, not fixing your problems
Old Dec 7, 2006 | 04:34 PM
RACEPAK's Avatar
Default Re: (CRXDrew)
yeah i got a restrictor.
10 40 isnt that heavy.
Old Dec 7, 2006 | 04:36 PM
A.E Motoring's Avatar
Default Re: (RACEPAK)
i used 20-50
Old Dec 7, 2006 | 05:00 PM
RACEPAK's Avatar
Default Re: (Dual Cam Racing)
did it worked for you?
Old Dec 7, 2006 | 05:10 PM
it helped a lil, but its just better to either rebuild the turbo or get a new one
Arturbo's Avatar
Better than steak
25 Year Member
Why not fix the problem?
RACEPAK's Avatar
cool. i have a spare turbo. i'm just too lazy to install it
Old Dec 7, 2006 | 05:41 PM
ZacCarter's Avatar
Don't oils all flow the same after they are at operating temp.?
Old Dec 7, 2006 | 05:50 PM
mrbsponge's Avatar
Default Re: (ZacCarter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZacCarter &raquo;</TD></TR><TR><TD CLASS="quote">Don't oils all flow the same after they are at operating temp.?</TD></TR></TABLE>
no they dont, some are formulated specifically for turbo/supercharged ingines and the heat they generate, i believe its is Mobile1 15 or 20w50, is the particular oil.
once 30 weight has been cycled thru a turbo for a bit, it goes from 30wt to damn near water, and with the amount of extra fuel most of our cars require it breaks oil down so much faster. i know my oil smells like straight up C16.
But if you start with something a little thicker, it will usually damn near thin out from the heat, to exactly where it needs to be.
you will hear alot of people in the N/A forums, say that 15w50 wont even get into our factory bearings, but i ran a built motor on it for over 4 years, just pulled it and there is absolutely nothing wrong with it, 11 second passes for almost 4 years
Old Dec 8, 2006 | 02:15 AM
blackeg's Avatar
Default Re: (mrbsponge)
i used to use 10w-40 with some lucas heavy duty oil stabilizer. kept a smoking setup going for thousands more miles, along with adding an oil restrictor
Old Dec 8, 2006 | 05:37 AM
AbitAvenger's Avatar
lucas' heavy duty oil stabilizer
Old Dec 8, 2006 | 07:59 AM
92gsrteg's Avatar
Default Re: best oil grade for a honda engine with a slightly smoking turbo. (RACEPAK)
hey, honestly since i switched to mobil 1 synthetic extended performance with my turbo jdm gsr, my freinds noticed a little bit of blue smoke when i really gun it hard, my motor was compression and leakdown tested and the guy said that the motor is in better condition than most N/A gsr motors and i know the turbo is good. i noticed my oil was gettin thin and not soo oily after like 2-3 weeks in the motor so i started using mobil 1 synthetic extended performan 15w-50 and everything started runnin better, no more blue smoke and seems stronger and faster. try bumpin up the oil weight with thicker stuff should help.
AccordVT
Jul 30, 2008 07:51 PM
motormike40
Sep 19, 2006 12:59 PM
CRXdan
Apr 4, 2005 06:28 PM
YashiMotors
Oct 15, 2004 08:04 PM
89civic1.8T
Jun 19, 2002 01:42 PM
