how big can bore be with 81mm wiseco b18c
i bought a b18c block with darton sleeves however i noticed when i put .010" oversized rings in the bore they dont need filling, they already have a .008" end gap. Can this block still be used with standard 81mm pistons or do I have get oversized pistons too
Re: how big can bore be with 81mm wiseco b18c (namm)
Has the block been used after it was sleeved or is it new? I would recommend getting it over bored or at least get it honed/check to make sure the cylinders wall are round. As for the piston/rings, check the specs with the manufactor and see if it falls withing their specs. Not all manufactor are the same.
Adriano
Adriano
I'd suggest measuring the bore - pistons need a certain cleanace, depending on the mfg's recommendation. Chances are its been ovaled out. The .010 rings are not a good idea in a stock bore, as Honda rings are low tension, and that would likely put too much pressure on the cyl walls.
Re: how big can bore be with 81mm wiseco b18c (Adriano)
I am aware that most piston manufacturers allow .004" piston to wall clearance. I would like to know how much bigger can piston to wall clearances be without causing exesive piston rattle
